Engine Specific Info and Questions => IDI Engine => Topic started by: simonfredette on May 17, 2017, 09:50:15 am
Title: AAZ crank bearings quick question
Post by: simonfredette on May 17, 2017, 09:50:15 am
I just noticed that the bearing kit I received comes with 4 flat bearings and 6 bearings with an oil channel, is this intended and if so which bearing cap gets a channelled bearing on top and bottom? Also, does anyone have a picture of the proper orientation of the thrust washers under #3, dont want to mess that up either. Thanks guys
Title: Re: AAZ crank bearings quick question
Post by: Dakotakid on May 17, 2017, 11:29:09 am
From a parts supply house:
"WARNING! Volkswagen OE design modification. Set contains (1) lower bearing shell which is grooved and WITHOUT OIL HOLE. Install in # 4 CAP position only!"
Post by: simonfredette on May 17, 2017, 12:44:47 pm
thanks Ill check , wonder what the reasoning is ..
Post by: Dakotakid on May 17, 2017, 02:52:16 pm
Oil supply splits directly above.
