Engine Specific Info and Questions => IDI Engine => Topic started by: caykroyd on February 07, 2017, 06:33:59 pm
I read a bunch about smoke and am confused about a couple things.
I have white/grey smoke at cold and idle which clears up once engine warms up. I think I've read this is ok, correct?
Then of acceleration (even moderate) I get a bunch of black smoke. So I know I can turn down the fuel screw, but I like the power ;-). Are there other options to reduce the smoke?
Thirdly, this seems weird to me.... At high cruising speed, I don't have smoke, but when I let off the pedal to slow down I get a huge plume of smoke. This seems counterintuitive to me. Does this make sense? Is this a symptom of something other that just running too rich? Why would this happen?
BTW, it is a Giles 1.6NA pump.
Sent from my iPad using Tapatalk
Maybe try contacting giles... The guy who built you the pump..
And if the smoke is thick and black you better have a egt gauge installed or you are likely to melt the pistons.
do you have guiles email? iīm from Brazil, here we donīt have a person to tune the pump.
Performance Diesel Injection in Ontario, Canada is his business. That's the easiest way to contact him.
