Engine Specific Info and Questions => mTDI Mechanical TDI Conversions => Topic started by: motohead1 on August 16, 2016, 08:02:25 pm
Is there a axial play measurement for the bosch pump? I picked up a LR pump and see some play in the mainshaft axially only when I turn the pump by hand. but I caint find the stock spec anywhere. Here is a video.
https://goo.gl/photos/kJt1XRftTorbTswV6
Hi, some guys in french section said me axial play in pump shaft isn't an issue. You can try many tdi-e pumps, they have often axial pump.
Envoyé de mon PLK-L01 en utilisant Tapatalk
Thanks.
Just be sur you don't have radial play in the shaft!
