Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: hillfolk'r on April 10, 2006, 08:25:21 pm
here ya are,,bout'time,,i got a couple up in the general section also,,where i was a sped on posting pics,,upgrades section ,,,,,,,,,,,it needed a wash,,i just wanted pics now!!!!!!!!!!too(http://img135.imageshack.us/img135/2427/hpim00779bs.jpg) (http://imageshack.us)
yo yo another one hehe(http://i2.photobucket.com/albums/y29/therabbittree/IMG00020.jpg)
it looks different now different fuel pump i built and I may be adding the second turbo soon..hehe
Later \x/ hillfolk!
Deo
sweet,,,whats the biggie the holset??,hey dragway 42 here in ohio has a test+tune fri.night,,im goin10$ to run all nite,couple of dudes at work goin too,,ill not touch a thing except my boost controller,,iinstalled my water injection tonite,,except i gotta get a piece of hose at work tomorrow,and fill+test it,,,i just wanna run it alot so i can see how it goes "right off the street"ill run it at about 27-28 psi,till i get it in top gear,then ill close it off,,im scared a little,,,i really need a bigger turbo,,its gotta be pumpin major,,,,,hope water injection will help some,,,,ill try a few things,,taking off in2nd gear,,,etc,,,, expect there will be a full report here afterwards in this spot:D :arrow:
close it offf
stop being a pansy ;)
close it offf
,,,dont worry i will,,but thats not the problem,,,,this is,,,,,,,,,Blake,
We have canceled Friday night. We will not finish construction in time.
As for the helmet, you do not need one until you get down to 13.99 or quicker. With a diesel, I doubt that you will be running that quick. If you do need one, it should be either DOT approved, or a snell 90.
Hope to see you soon,
Toby
cut+pasted email i got todayt :cry: :cry: :cry: :cry: :oops: :cry: :cry:
ha well it gives you time to make sure you need the helmet..hehe.. I am doing the motor mount ..it sucks i had to dropp it down and out teh boottom and its back in now i have to redothe pump and th et belt argh thats sucks haha..later
Deo
hope it fixes the vibes problem,,are ya gonna fill it or anything???
naw not filling it..i did notice the exhaust is hitting the bottom of the car now where the ebrake tube and my shifter are home made hanger..argh..I'll have to reengineer it hehe..I hope that and the motor mount were the main issues with the vibration. I am playing with the idea of mounting my twin turbo now, and redoing the front half of the front exhaust in 3" as the back is 3"... when I remounted the pump I did the timing at 1.05mm.. before I had 1.15mm...ah I hope she runs well ,and if I can get some one to let me use their aluminum welder, then I'll weld my intercooler tubes up. then I can mount that sucker too. I noticed my bed seams are loose ie some spot welds are broken. It's neat cause its rust free, being from colorado,..so i think the bed floor vibration may have added to the vibration in the cab. I will be redoing some of the welds there soon. I got the other poly race seat mounted and both now sport camo seat covers hehe cool. I hope to paint it and rhino line the bed and rockers sometime this summer.
later,
Deo
watch those spot welds,,remember my truck,,shockmount rotted off,icould see the bed bounce up and down on the bumps,,,,ihad a feeling those vibes were from exhaust ,,but mount didnt help,,,,,,,,yea, i got my timing set up around 1.00 myself,,didnt try much more than that,,,,yo i got those rabbit stickers,,i was gonna take em to kinkos or somethin,and scan them(mines boxed up,i thinkits actually back there in ny),,so i could have a sticker shop reproduce them if i ever wanted,,,, :D
yeah well i noticed it because i was taking a break sitting on the back of the bed and noticed the edge was flexing so i looked closer and the back edge was separated and the drivers side had a littel you good flex the bed metal up and down ..wierd as it has not rot just some surface rust ..you could see the indents from the spot welds..i guess they weren't to good ..huh..i think I'll stich weld it..and check the under bed seams too... i am debating using my eaton m90 and my holset m90 in a staged setup..on it..it could be pretty cool...debating on where to mount the supercharger..i don't want it on teh front ..but in the back with a offset turbo mount...mummn
later
Deo
\x/ hillfolk!
I wanted to post pics of my M-tdi but don't know how
I noticed the pump timing some of you are using is between 1.05 to 1.15mm. I initially set mine pump to 1.00mm and the engine is very, very loud compared to an electronic pump tdi. I was using the factory airbox, and it actually made the intake noise worse because it was acting like a megaphone. I installed a K&N cone filter and it's actually a little better because it's just as loud but it's a different loud. You can really here the turbo spool up which sounds really nice.
I have a custom pump pulley setup from an ALH setup and I retarded the pump timing so doesn't sound like a cummings or john deere tractor(that's what my non-diesel head friends say anyway). It's really easy to change pump timing, 3 allen head bolts.
I marked the original 1.00mm setting and I retarded the timing until the engine started to run poorly then brought it back....I did the timing by "ear". it's not back at the 1.00mm mark and it's a little less "dieselly". I'm actually a little disappointed by the amount of noise.
What I also found strange was the 11mm pump has absolutely no cold start advance mechanism. It's starts right up in the cold but if it had a cold start advance I could retard the timing a little more and advance the timing when it was cold. I'm currently running approx 20-25psi of boost and I only use 1st gear starting on a hill, otherwise I always start in 2nd.
wow,thats cool,,yea its less dramatic taking off in 2nd,, basically i use first to get the car rolling then get 2nd,,,7a trans here,,acts like a close ratio behind a 1.6td,with all the power,,i will sayit does have more intake honk, than my old 1.6td,sounds like a 1.6 na,with the air cleaner housing off,,i wonder if an iintercooler would silence it some,,,,mostly the turbo whisle comes from straight pipe exhaust,,,
Very good description of the intake noise...it does sound like a rabbit 1.6 n/a come to think of it. I installed the tdi CTN 02A cable shifter tranny in my A2. My tdi has the factory GTD intercooler and the noise is still there. The noise is coming from the intake side of the turbo so I don't think it would matter if it was intercooled or not.
If I good figure out how to post pics I would.
noise is good..hehe..I like the louder diesel sound and turbo / intake noise is even better..
if I send you pics of my engine setup will you post them for me?
yea man :wink: :D i like pics!!
i just learned this here theother day,,,,you have to get them hosted,,,,i canpost em 4 u too though
http://imageshack.us/
I need your email address
open a photobucket account..its free then you can upload pic to the 'net.. then to post on a website you just copy the IMG address of the pic its pretty simple.... www.photobucket.com
thanks
deo
aargh,,dragway 42 is still redoing the track they said today,they may be ready for saturday t+t, from like 6to11pm, 10$,but im not counting on it ,quaker city had testand tune tonite,,,norwalk canceled cause of rain,,,thompson has t+t on saturday afternoon,2 to 5 , like 12$,,,,PLEASE,pray for no rain tomorrow!!!!!i wanna timeslip
Let me get this straight: A "TDI-M" is basically a TDI motor with a mechanical IP?
And the injectors?!
injectors are from the tdi,,i got race 520 kerma nozzles,,just leave cyl 3 lift sensor unhooked,works great!!
