Engine Specific Info and Questions => IDI Engine => Topic started by: mk216td on April 07, 2016, 09:51:28 pm
Title: T25 flange 8v exhaust manifold?
Post by: mk216td on April 07, 2016, 09:51:28 pm
Does no one make them? All of the ones I've seen that are listed as "T25" have the same bore of a T3 but with the T25 bolt pattern, like they are all cast as T3 units but they drill whatever bolt pattern you want after which makes the T25 version useless...
I'm purchasing a small Holset for my Ecodiesel in a couple weeks and trying to figure this side of the swap out. Any help would be appreciated.
Sent from my SM-G920V using Tapatalk
Title: Re: T25 flange 8v exhaust manifold?
Post by: camboscams on April 14, 2016, 06:31:52 pm
This is the one i bought, it was a little cheaper then but is of pretty good quality.
http://www.ebay.com/itm/TURBO-manifold-cast-for-T25-Flange-for-FOR-AUDI-VW-8V-/111807231153?hash=item1a083af4b1 (http://www.ebay.com/itm/TURBO-manifold-cast-for-T25-Flange-for-FOR-AUDI-VW-8V-/111807231153?hash=item1a083af4b1)
Post by: theman53 on April 18, 2016, 07:55:34 pm
my holset is t25
Post by: mk216td on April 19, 2016, 11:23:53 am
See I was looking at that one too, but seems like it has the T3 sized exhaust outlet. Do you remember how it looked for size or have any pics?
Post by: mk216td on April 19, 2016, 11:25:09 am
my holset is t25
Which Holset did you get and how do you like it? I should also ask what manifold you run too haha
Post by: golfmk1tdr on April 19, 2016, 03:48:18 pm
I think my manifold is the exact same, I'ts really annoying that T25 gasket doesn't really fit since center hole is too big,
but I put it on with gasket anyway and it was holding fine.
EDIT// just checked the price, whoa I thought I was paying dear back then, but this really is a bit much... Someone is busy earn'n there, this piece probably cost 10 bucks delivered from China. I am definitely learning mandarin next year  ;D
Also: high quality german product? Not with that ugly cast lines all over it it ain't, also ''Ta technix'' is Austrian firm...
Still, it works  ::)
Post by: mk216td on April 19, 2016, 03:58:03 pm
Well how does that work going into the exhaust housing of the turbo since it's a smaller inlet? I feel like all the exhaust would be hitting a wall if you know what I mean.
I know, I do see some from China, but T3 for like $20, but who knows what shipping costs.
Post by: theman53 on April 19, 2016, 08:10:06 pm
my holset is t25
If you look at my sig line in build thread 2 you will have all you can read on what I did to the car. I have the HE221w and an ebay cast iron t25 manifold I gave around 90.00 for 3 years ago.
Post by: mk216td on April 19, 2016, 08:56:10 pm
my holset is t25
That's the same turbo I'm going to run, the 5.5 cm version. I guess it was easier to come by T25 manifolds then. Getting emails back from ebay sellers is the worst too.
I would, but this tapatalk thing is confusing to me...
Post by: Jetmugg on April 20, 2016, 01:42:47 pm
I'm using one of the Ebay T3 manifolds, combined with a T3-T25 adapter.  If I had it to do again, I'd probably spend the extra money for the dedicated T25 manifold.
I'm using an HE200WG turbo.
Steve.
Post by: mk216td on April 20, 2016, 07:19:13 pm
Steve.
I thought about running that adapter too but I'm not sure I have enough room in a Mk2 engine bay, it's gonna be close.
Post by: theman53 on April 21, 2016, 07:39:11 am
Steve.
You won't have room. Mine without the adapter is 1/4" to maybe 1/2" off the firewall with no adapter.
Post by: mk216td on April 21, 2016, 08:11:52 am
Steve.
I take it you have a mk2 also? The guy I'm buying it from sent me a pic of the length from the manifold he sells to the back of the he221w and I'd say 9" to be safe? I measured 10" from my cylinder head to firewall in about the position it will be in.(http://uploads.tapatalk-cdn.com/20160421/f88ff06b053d317aecd97827e8e89882.jpg)
Post by: theman53 on April 21, 2016, 08:16:18 am
http://www.ebay.com/itm/TURBO-manifold-cast-for-T25-Flange-for-FOR-AUDI-VW-8V-/111807231153?hash=item1a083af4b1:g:9KUAAOSwHnFVrmKj&vxp=mtr
Yes I have an 86 jetta. look here if you want http://vwdiesel.net/forum/index.php/topic,31758.0.html
That is the T25 manifold in the link, same as I have. If you put a couple gaskets in between the turbo and the manifold it won't work. It may fit for a second, but I am running some poly engine mounts and still sometimes will hear the turbo kiss the firewall. That engine moves remember and listen, it will not fit without cutting your firewall with an adapter.
Post by: theman53 on April 21, 2016, 08:17:59 am
Here is another... http://www.ebay.com/itm/VW-Corrado-Jetta-2-0L-8V-1-8L-G60-PG-Turbo-T25-Exhaust-Manifold-Turbo-Manifold-/351667846098?hash=item51e1097bd2:m:mqWWoYffYYP4En0Z_eHx14A
it cost me around 1,000 dollars to buy and mount my holset, labor was free as it was mine. It isn't a cheap endeavor
Post by: mk216td on April 21, 2016, 08:27:23 am
Those manifolds still have the huge T3 sized exhaust outlet but drilled for a T25 bolt pattern. I don't understand how they can even be sold.
Ya I hear you there, I was just thinking that would be an option to run an adapter until I actually measured the distance I have haha.
I have a solid front mount on mine. The guy I'm buying the turbo from must have the only true T25 manifolds left in the world... it's $350, but might just have to run it.
$1,000 don't seem to bad for a turbo setup especially when some bigger VNTs are running $1200 alone. I'm looking forward to it!
Post by: Jetmugg on April 21, 2016, 09:12:35 am
Another option would be to contact Fred Sundstrom at F-Tune Performance.  He is in the business of fabricating custom tubular exhaust manifolds.
Regarding the T3-T25 adapter route, you guys are 100% correct that it won't fit without modifying the firewall.
Steve.
Post by: theman53 on April 21, 2016, 08:24:50 pm
I just linked you 2 under 200.00
Post by: mk216td on May 05, 2016, 07:26:32 am
(http://uploads.tapatalk-cdn.com/20160505/d6b3b13870b66d6ec6e57c5067caba9d.jpg)
We'll I received my manifold with a true T25 flange, just need to gasket match a little. Can't wait to get my turbo!
