For Sale/Looking For => Parts for Sale/Wanted => Topic started by: william.smith on January 25, 2016, 12:36:36 pm
Title: 11MM Bosch mTDI pumps - LR 300TDI Pumps
Post by: william.smith on January 25, 2016, 12:36:36 pm
Now I have successfully got some into the USA, I am happy to offer a few more out. They are meticulously drained, then packed in plastic, plastic a sealed plastic container surrounded by foam in order that they arrive undamaged and they don't stink of diesel when they are sat on the desk at customs.
I am selling them on the basis that they came out of cars that ran, I can't guarantee the seals. Personally, I would change these anyway. Seals are available stateside.
These are 300tdi LR Pumps that can be fitted to all 1.9 Direct Injection engines with little modification to your bracket/pulley setup. All depending on what engine code you are starting from.
375usd shipped to the USA. At this price they are a steal.
Any questions drop me a message!
I am able to provide a machined out pump bracket with the pump if this is required (AHU/1Z ETC).
(http://i1191.photobucket.com/albums/z468/Williamjsmith/Screen%20Shot%202016-01-25%20at%2020.33.41_zpsktjnriym.png)
Title: Re: 11MM Bosch mTDI pumps - LR 300TDI Pumps
Post by: libbydiesel on January 25, 2016, 04:44:39 pm
It's nice to have another potential source.  How much would you charge for machining the AHU bracket?  How much would you charge to machine the LR hub so that the ALH sprocket fits properly?
Post by: william.smith on January 25, 2016, 10:53:17 pm
The main issue with the bracket is that it's quite a lump to ship. I would need to weigh it and work out how much extra shipping would cost with that in the box too. I can do the bracket including machining for £60. You don't need to return me your bracket at that price.
I don't have access to be able to machine stuff on a lathe for other people. I can squeeze on there for the off thing for myself but that it. Does the alh hub sit the pulley correctly? That's something I, personally, have never tried.
Will
Post by: vanbcguy on January 26, 2016, 09:56:48 am
The ALH hub AND pulley work together great on the LR pump.  The LR hub however doesn't have the correct offset for the ALH pulley, but I think the bore diameter is the same?
Post by: william.smith on January 26, 2016, 02:56:32 pm
On an ALH, the pump fits straight in the bracket I believe. On ahu/1z the bracket needs the hole opening out
Post by: william.smith on February 11, 2016, 01:46:02 pm
any more takers?
Post by: Ian0391 on February 11, 2016, 02:11:05 pm
How much shipped to Canada?
Sent from my SM-G920W8 using Tapatalk
Post by: william.smith on February 12, 2016, 12:34:30 pm
$385 posted.
Post by: Ian0391 on July 25, 2016, 09:14:17 pm
Do you still have many of these?
Post by: william.smith on July 28, 2016, 02:18:40 pm
Yeah. I'll send you a PM.
Post by: prpshp on August 01, 2016, 06:13:59 pm
I would like one of your m-tdi pumps I have a 1997 1z engine going into aSamurai
                    Thanks, Kevin
Post by: Green Syncro on August 01, 2016, 10:40:07 pm
Hello William,
Please contact me via email on my profile.  Interested in a LR pump as well.  Thanks, Joel
Post by: MR Green on August 12, 2016, 09:50:18 pm
Hello William,
Please contact me via email on my profile.  Very Interested in a LR pump.  Thanks, Mr Green!!
Post by: LabradorSteak on August 20, 2016, 10:51:49 pm
I am also interested in a 300tdi lr pump.  email me or pm me please.
Matt
mlhoppen
at
gmail
.com
Post by: william.smith on September 04, 2016, 01:11:26 pm
Anyone else?
Post by: JoeErnest on September 08, 2016, 01:04:20 pm
Got pumps?
I'm looking to put a 1Z/AHU into an 82 Diesel Westy, and mTDI seems to be the way to go.
Besides  - Transfer AHU pulley to LR 300 pump
               machine the mounting bracket hole larger for LR pump
               advance and governor - keep stock
               set timing by hand.
What else should I know about getting the LR300 pump to run a 1Z/AHU?
$375 shipped to Fresno CA 93705?
Post by: Hxmaster on September 14, 2016, 10:57:37 pm
I would like to buy one!
Post by: Hxmaster on September 14, 2016, 10:59:11 pm
I want one!
Post by: william.smith on October 16, 2016, 01:29:58 pm
Still have availability. Anyone else?
Post by: blackdiesel on November 24, 2016, 07:17:32 am
I'm interested. i have an ALH going into a tracker. What else will i need to mount/align it with the timing belt?
Post by: vanbcguy on November 27, 2016, 08:44:48 pm
Just the pulley and hub from the original ALH pump plus the delivery valves from the ALH pump. The snout is the same length and the shoulder is the same diameter as the ALH pump so it bolts in just fine. The ALH pulley and hub are needed for the timing belt to line up and the delivery valves are needed for the injector lines.
Post by: Ian0391 on November 30, 2016, 09:04:10 am
Do you still have more?
Post by: alex17young on December 21, 2016, 11:12:11 am
Are there pumps left? -thanks
Post by: william.smith on December 23, 2016, 11:29:50 pm
Yeah. Drop me a PM!
Post by: foxfour on January 30, 2017, 03:31:49 pm
I emailed you about an hour ago that I'd like to buy one of your pumps for my 1997 Jetta 1z TDI engine - if you still have one left.
Post by: Nevadan on March 07, 2017, 02:08:51 pm
I'm interested in getting one of these, are any still available?
Post by: william.smith on April 02, 2017, 12:09:48 pm
Up
Post by: sammy dieseld on June 29, 2017, 04:28:18 pm
Do you have the bracket to mount the rover pump to the ahu engine?
Thank You,
Greg
Post by: ketchupshirt88 on June 30, 2017, 08:10:40 pm
pm sent
Post by: air-cooled or diesel on July 02, 2017, 05:18:54 pm
PMed
Post by: trekker6 on July 07, 2017, 07:51:24 am
I'd like to the pump and bracket for a 1998 ahu, are they still available and do I need anything else for installation?
Thanks
Post by: butch2000 on July 24, 2017, 08:03:36 am
I'm looking for a upgrade for my AAZ engine ? what do you have ?
Post by: BadIntentions on September 20, 2017, 01:45:04 am
Dont suppose you have any more of these pumps available?  Snoopin' around for one for my ALH.
Post by: dlgmedia on October 09, 2017, 01:31:48 pm
finally! I'm in need of one. I have a ahu donor car and want to put it in my mk1 1.5. - Need the bracket and too.
Thanks!
Post by: Nero Morg on October 17, 2017, 11:48:32 am
I know it's a bit of an old thread, but do you still have one of those pumps?
Post by: Smoker on November 18, 2017, 09:37:05 am
Has anyone here actually bought a pump from this guy?
Sent from my SM-G955U using Tapatalk
Post by: william.smith on January 10, 2018, 02:15:27 pm
All,
Didn't realise I had missed a load of messages in here!
I still have these pumps and am still shipping them over to you guys. Over 250 sold now in two years!
www.wheeliams.co.uk is my website if you want to have a look. If you go on the VWdiesel facebook page, I sell most of the pumps in there and there is a very long thread full of information and people backing them up.
If you've got any questions please drop me a message!
Post by: jimbote on July 27, 2019, 03:33:47 am
bumping this up for rover pump hunters ...
Sent from my SAMSUNG-SM-G891A using Tapatalk
Post by: Chuck1978 on November 15, 2019, 04:01:58 pm
So you are still selling these? What is the current cost? And is that shipped, to USA addresses? I'm considering picking up a spare.
Thanks!
Post by: Chuck1978 on November 18, 2019, 08:17:16 am
I'm not sure if he's checking this website forum much, but he is doing these still if you contact him through his website or various VW diesel facebook groups, AFAIK
