General Information => Troubleshooting => Topic started by: aslspiderman on September 21, 2015, 06:12:02 pm
Hi All--I have a little dilemma. Went in for a smog check on my 98 TDI and it failed because EGR readiness will not set. At this point I'm a little stumped. I've driven the car about 500 miles since replacing the clutch, (battery disconnected) including a trip of almost 200 miles the other day with some spirited on-ramp accelerations.
The car is chipped (no details, I purchased it that way). That being said, it has passed twice before with no problems. Vagcom shows the egr cycling on and off. So I'm assuming it and the N-18 valve is functioning properly. I also used a mityvac to manually check the EGR and it starts opening at 10" of vacuum and opens fully by 15"
My coolant temp is at 183* according to vagcom. All my vacuum hoses are properly connected and in good condition.
If anyone has experienced this or could give me any hints on what to do, I would greatly appreciate it.
Thanks in advance for any and all help
Mike
There is no readiness on your car.
Sent from my SAMSUNG-SM-T337A using Tapatalk
Actually the model year 98 and newer does. and Ca. smog does check for it. 97 and older does not require smog check. So--I'm still trying to figure it out, any help would be appreciated.
Found out the problem--faulty MAF. New MAF, readiness set, passed smog--good day ;D
