For Sale/Looking For => Parts for Sale/Wanted => Topic started by: Orb95 on September 09, 2015, 08:22:22 am
Title: WTB Garrett Air Research T3
Post by: Orb95 on September 09, 2015, 08:22:22 am
WTB garrett T3 that will mount to the original 8v 1.6td manifold in good condition with no shaft play. Message me with what you have. Thanks.
Title: Re: WTB Garrett Air Research T3
Post by: libbydiesel on September 09, 2015, 08:33:53 am
...in good condition with no shaft play.
Just trying to help...  those two conditions are mutually exclusive.  Brand new they have fairly noticeable radial shaft play.  The only journal bearing turbos that don't have fairly noticeable radial shaft play are ones that have coked up bearings from being run hard and put away hot.
Post by: RabbitJockey on September 09, 2015, 08:39:10 am
yep, even with a 360 bearing mine has up and down shaft play.
Post by: RunninWild on September 09, 2015, 03:38:21 pm
I've got one. I didn't notice much if any play. I've never tried to use it but it looks like it's in recent shape. That being said it needs the waste gate actuator diaphragm replaced. Looking to get $100 and I can throw in the diaphragm.
Post by: Orb95 on September 09, 2015, 06:16:23 pm
I'm looking for a new turbo mainly because mine seems to be hemorrhaging oil. I have replaced the valve cover and oil pan gasket. The motor is still leaking oil like crazy and the underbody is dripping wet. I have access to a lift and can see oil all over the bottom of the turbo and coming out of the wastegate. Also when I remove the intake hose from the turbo there is a puddle of oil. The turbo still boosts but i believe the seals have gone bad.
Post by: theman53 on September 09, 2015, 07:01:20 pm
Is it turbo or way too much blow by?
Sorry really shouldn't jam up the FS as it is FS only, but you should know before buying something you don't need
Post by: Orb95 on September 10, 2015, 11:58:39 am
I will be looking into blow by issues soon. Whenever I get a spare moment.
