Engine Specific Info and Questions => TDI - Common Rail TDIs => Topic started by: Connect123896 on July 26, 2015, 06:06:59 pm
Title: 09 TDI DPF and nod canister filled with oil
Post by: Connect123896 on July 26, 2015, 06:06:59 pm
My turbo went bad and puked all my oil in the exhaust , I am having my turbo rebuilt but my exhaust is filled and the pressure from the exhaust was causing my engine to spew oil out of the valve cover vent. What is the best way to clean it to prevent blowing seals ? Pressure washer ?
Title: Re: 09 TDI DPF and nod canister filled with oil
Post by: ORCoaster on July 27, 2015, 06:23:06 pm
If I had an exhaust system filled with oil I would either take it off and drain it out piece by painful piece or....
Take it off and light it up with some gas down the top side.  And then prop it up to the shining moon to enhance the glow effect.  Your safety is our concern.
Post by: Connect123896 on July 28, 2015, 09:08:56 am
I would probably go with the gas option lol does anyone know how to get the dpf and nox canister out ? I know the k member it in the way big time
