Engine Specific Info and Questions => IDI Engine => Topic started by: sethyboy85 on April 01, 2006, 05:49:59 pm
Title: quantum motor?
Post by: sethyboy85 on April 01, 2006, 05:49:59 pm
whats the difference between a quantum 1.6lTD and a regular TD, I am guessing only mounts right?
could it be made to work in a jetta easily?
as far as I can tell it used different intake/exhaust but other than that
Post by: veeman on April 03, 2006, 08:27:49 am
Yep... Andrew's right. There are differences in the accessories.  I can personally vouch for the fact that the alt / AC bracket is different than the normal A1 / A2 TD bracket.  It's only slightly off, but different enough to make the alt mounting a headache.
FWIW, I have a motor from a Quantum in my caddy TD right now.  It's got all the correct manifolds for an A1 on it though.
The important thing is that the block / head is the same.  You can probably source the manifolds and brackets from people here that have extras.
Post by: dennis m king on April 04, 2006, 06:53:30 pm
i put a 83 td diesel in my A2 jetta. had to get a exhaust manifold and ended up getting the A2 oil pan and pickup. works great. exhaust manifole was hard to get for td A2.
Post by: sethyboy85 on April 04, 2006, 07:22:28 pm
hey, it's great to see somebody else in central PA running on RUG/WVO
I got manifolds but I think I am going with a ecodiesel motor with half the miles. I have a 2 turbo pumps so I will eventually make it a TD
thanks for all the replies
