General Information => Troubleshooting => Topic started by: Deanow24 on February 13, 2015, 03:14:24 am
After a short while driving my gtd cuts out and loses power? Any suggestions
It's running a large FMIC pumps modified and 23psi of boost
Thanks for any suggestions
Fuel starvation is pretty much the only option.
How old is your filter?
unsure of that! as only recently started using it after buying it, but im doing a complete service this weekend so hopefully that'll sort it
A clean filter first of all. If you're still having problems then things will get more interesting. Any chance the car has had WVO or other "alternative" fuel run through it?
Also, check out the wire going to the electromagnet on the back of the fuel pump. I know mine gets loose at the connector sometimes causing it to cut out and not start on occasion.
install clear fuel lines.
