Engine Specific Info and Questions => mTDI Mechanical TDI Conversions => Topic started by: countach on January 04, 2015, 12:31:11 pm
Title: install my mtdi pump 0460424138 but what should I set the timing to?
Post by: countach on January 04, 2015, 12:31:11 pm
the Engine is a 1Z and the nozzles are set to 210 bar but what should i set the timing to??
Title: Re: install my mtdi pump 0460424138 but what should I set the timing to?
Post by: vanbcguy on January 04, 2015, 02:01:58 pm
What's the pump from?
Post by: countach on January 04, 2015, 02:44:54 pm
the pump is from vw lt28 lt 46 2.8tdi mechanical pump
Post by: rodpaslow on January 08, 2015, 07:49:12 am
My pump is a vw pump with land rover internals - it's a bit of a hybrid because wanted to just be able to bolt it on.  With mine running currently stock 1Z/AHU injectors I have it set as far advanced as possible (pump slots at max toward engine) at 1.40 using the dial gauge.  This should equate to about 12° BTC.  I starts beautifully even at -30°C now that we have winter.
I would start at 1.3 or so (if you have dial gauge).   The Mtdi pump needs to be much more advanced than the old IDI engines.  My $.02
Post by: vanbcguy on January 08, 2015, 09:27:42 am
I'm running a Rover pump too... Mine is at about 1.40 give or take, I used the dial gauge to get it in the neighbourhood and then used my pulse adapter and timing light to find 12° BTDC.
I know I've seen mention of the LT pump around quite a bit but I'm not sure if anyone on here specifically has run one.  Lots of Rover / Cummins pumps though.  The cam plate / head are different in the LT pump so the Rover numbers aren't going to mean all that much.
Post by: rbremiller on January 11, 2015, 03:23:15 pm
I've run the same LT 2.8 pump you have for 2 years. .90mm is a good starting point for timing this pump.
Post by: 745 turbogreasel on January 11, 2015, 08:24:12 pm
Some say 12 degrees at  idling speed  is a good start.
Post by: vanbcguy on January 11, 2015, 10:03:13 pm
12 degrees works great for me. But you need a light to find that. With any luck one day someone with an LT pump and someone with a pulse adapter will be in the same place at the same time...
