Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: TDIVdubs on December 16, 2014, 02:39:00 pm
Hey guys, I have an MK4 TDi jetta. I recently replaced the injection pump seals after they started leaking. I used Vag-Com to tune in my IQ (Injection quantity) to around 3.2. I thought I read that it should be set between 3 to 4.5. But my question is, I had replaced the stock nozzles for my injectors with Bosio DCL PP520 nozzles about 40K miles ago and wasn't sure if I needed to adjust my IQ for the larger nozzles? Now that i have Vag-Com and can adjust the IQ, should I leave the IQ where I have it? or should I adjust it higher or lower with the slightly larger nozzles ??? I'm a noobie to vag-com and IQ info, so I don't know if I should even bother adjusting it from where I currently have it. Thanks
I think once you put in new nozzles you sometimes need to adjust the IQ if it goes out of range. If it's running well and you like the power I'd leave it alone.
Just as Tyler said, adjust it manually or vagcom, to where you like it.
There are limits, but you would quickly figure that out. I upgraded to the race520 and it was recommended to adjust to a more conservative IQ, but I preferred it down at 2.7, just feels torque-er and I like the smoke.
Sent from my 0PJA2 using Tapatalk
