Engine Specific Info and Questions => IDI Engine => Topic started by: shelbot on November 29, 2014, 01:50:28 am
Title: pistons
Post by: shelbot on November 29, 2014, 01:50:28 am
Hello I just had my head rebuilt and now about to do the bottom end. I bought a bunch of parts a few months back off a guy claiming everything was parts bought from vw. I didn't know very much and long story short I have these ARCO pistons that would be perfect for my build as I need this back together asap but I know if they are junk I'm going to regret it. If these are junk then what brands are strong enough to handle 20+ psi? Thanks!
Title: Re: pistons
Post by: theman53 on November 29, 2014, 08:30:11 am
The pistons are ok. I had them on a build I skimped on, but the rings seem to be garbage. I only would recommend the Goetze rings for any piston you go with. I don't like giving any $$$ to Prothe/hans/whatever else he goes by, but if you already have them you can use them. I went 20+ psi for 40,000 miles on mine.
Title: Re: pistons
Post by: shelbot on November 29, 2014, 03:13:55 pm
Thanks. So i'm still having a hard time getting any pistons for my engine. I'm trying to go through lordco or bakers but neither are having any luck. So I guess I will throw these in for the time being and hope they last me 30,000 kms. I will be running 20psi on my t3, arp head studs, new bearings all around, seals ect. I can't even locate a victor rienz head gasket. I'm from Vancouver Island BC so things take a bit longer to get here also as the mail system is just silly! I would love any sites that I can direct buy from also any part numbers for the 86 1.6l td engine parts/gaskets. I'll keep sniffing around forums and the net but honestly I'm better behind a wrench than a keyboard. My searching skills are weak i'll admit.
Title: Re: pistons
Post by: libbydiesel on November 29, 2014, 05:47:56 pm
Is this a 1.6TD?  If so then AutohausAZ has an excellent price on OS kolbenschmidt pistons.
Title: Re: pistons
Post by: TimpanogosSlim on November 29, 2014, 09:35:58 pm
I don't think an NA engine would be offended that the piston skirts have cutouts for oil squirters that aren't there, would it?
Title: Re: pistons
Post by: libbydiesel on November 30, 2014, 08:37:24 pm
The cutouts wouldn't matter, but in his post he says he's planning on running 20 psi so I assumed either 1.6TD or AAZ.
Title: Re: pistons
Post by: TimpanogosSlim on November 30, 2014, 09:12:55 pm
Ah. Yeah, 1.6NA block should accept 1.6TD pistons with no issue though, which was all i was sayin.
Title: Re: pistons
Post by: TimpanogosSlim on December 01, 2014, 02:13:16 pm
Goetze makes an mls head gasket that will work fine for you. There is a part number in the faq section.
At least, in your 2nd post you refer to a 1986 1.6td? Mk2 hydro head and td or na block?
.:Sent by pneumatic tubes
