For Sale/Looking For => Parts for Sale/Wanted => Topic started by: vwsnaps on November 04, 2014, 11:01:07 am
1998 Volkswagen Vw Jetta TDI Turbo Diesel - Parts / Donor / Project Car
located Nebraska
$2000 - OBRO
1998 Vw Jetta TDI
AHU - 1.9l Turbo diesel engine - Just installed new timing belt this week along with tensioner
5 speed Manual Transmission
217,000 - miles shown on the odometer
Silver body is rough - dented fenders, doors , hood , broken grill , part of rear bumper cover missing, passenger headlight might be broke , missing interior lower glove box.
Interior is FILTHY - dirty - tons of dirt , rocks , gravel and previous owners trash still in the car.
Steel wheels with tires that hold air - not sure they are good but they do NOT go flat.
Battery is DEAD - will start with a JUMP START.
Car needs brakes - car will need towed!!! The brake pedal is soft and wont build pressure - you can pump them to slow down but i would NOT DRIVE THIS - TOW AWAY
I bought this Mk3 TDI as a donor car for an Mk2 Jetta Coupe Project ( for sale ) that i have decided to bail on. I bought this car not running , previous owner ran it out of diesel.
I primed the pump got it running and noticed the timing belt was in very bad shape ( old , needed replaced ) so i decided to do it so it didnt break and cause engine damage )
I expect this car to be a donor car to used in Jeep , Suzuki Samurai , Old Vw like i was going to do?
Car has NO sunroof , manual windows , cloth dirty interior , i dont know if the radio or Ac or heat work - you put a jump box on the battery, it starts right up. Previous owner has black tape covering the Check Engine Light on the cluster - i have NOT scanned it to see why its on. Its does NOT run in limp mode - cant really get it up to speed since there are NO brakes - master cylinder is full of fluid so i am assuming the brake booster is bad - but that is only a guess.
Did i mention the Jetta is FILTHY and i do not plan to clean it.
SOld AS IS WHERE IS - Outside Lincoln Nebraska - WILL NEED TOWED - Once you pay for it , you can drive it / tow it away - no test drives since it has no BRAKES.
These TDI swaps sell for good money - i did timing belt so its ready to drop into another car or fix up this beast and get 45 MPG all day long.
My daily driver is another 1998 TDI. I love it.
402-671-0355 - TEXT ONLY - if you have questions.
I might consider a trade for an older Volkswagen Rabbit Pick up truck - diesel or gas - or an older Jetta , corrado or dune buggy ? Manx ?
(http://i1055.photobucket.com/albums/s510/volkshole/BCD3FFA2-4811-4947-96FB-A5B7150284F8_zpsbkttnruf.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/FD740A01-145B-4CBE-A59C-691596D2FCE8_zpsrlm3an4e.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/A8DA48B1-00F4-4199-9669-2EE4D0D80A93_zpsqpa0xals.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/5E410509-C339-46DD-9408-83664E50B31B_zpsnjhvlue6.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/FE48957B-59F3-4477-858F-D1266C7075E8_zpsvaoqtlru.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/29D3AB36-0907-4A56-BD78-B5D22E723AE4_zpshjdallpy.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/DF3C0B83-2F72-4786-AC95-807B521BCD39_zpso5it8zhx.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/F6D99478-CE04-4096-A932-B4290B214BD0_zpsf5jhc8i4.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/EAC9646E-2E23-44F5-A830-943AB105DC76_zps9rlukz2e.jpg)
(http://i1055.photobucket.com/albums/s510/volkshole/B9FDB475-76CA-4605-B001-9560135615B2_zpsmshl7czu.jpg)
