Engine Specific Info and Questions => IDI Engine => Topic started by: MadCityMike on March 25, 2006, 12:22:49 pm
Title: What's the best coolant
Post by: MadCityMike on March 25, 2006, 12:22:49 pm
Do the 1.9's need any sort of SCA additive to the coolant?    Is cavitation a concern with these motors?    What's a good coolant to use?
Mike
Title: Re: What's the best coolant
Post by: jtanguay on March 25, 2006, 01:38:06 pm
Quote from: "MadCityMike"
Mike
pretty much any coolant should be good, except the pink gm crap.  does any one use water wetter???
Post by: GTD. on March 26, 2006, 12:55:07 am
Iron blocks VW G11 (blue)
Alloy blocks VW G12 (red)
or use G12+ (purple) which can be mixed in either G11 or G12
DO NOT mix G11(blue) and G12 (red) as they make a gel which can block water ways and pipes when mixed!
From empty use 2 bottles then top up the resevoir.
Post by: BellCityDubber on March 28, 2006, 11:27:36 am
Quote from: "jtanguay"
Mike
I used water wetter in my 8v and my vr6...
it dropped temps a bit... not a LOT, but enough on a spirited drive..
I'm planning to put it into my TD and maybe perhaps I'll get some real world ##'s for people....
Post by: hillfolk'r on March 28, 2006, 04:20:05 pm
gtd  got it,,,,,,i do use dexcool,i never had a problem,,and iuse water wetter,,,iused almost a double dose of w.w.,,,barely noticed that,,but it does cause better cooling,not like it ran way cooler,but maybe a few degrees when beating onit,,,,,,,,,,her 99 i onlyuse the vw antifreeze g12 pink??i think,,,,dexcool is way better than green stuff,,,green stuff is crap,,,silicates are a killer!!!!ever seen silicate dropout???very ugly,and not fun to clean out,besides silicates are abrasive,why put sand in your cooling system???say no to green coolant,dont mix em either
Post by: dieselweasel on April 01, 2006, 10:53:11 pm
I've never heard of cavitation erosion problems with these engines probably because the cylinder walls are relatively thick.  You really should use SCAs or a long life coolant that doesn't require them, but you can probably get away without.
Post by: hillfolk'r on April 02, 2006, 05:02:47 pm
if you had a big truck,,use sca's.it holds 10-15gallons,,alot$$ to change.but since our systems barely hold 2 gallons its cheap to change,,,dont need to use sca's,,just changeit,,,you could get that litmuspaper test strips,,tells the acidity of coolant,,,,,,,,,i know ford put out a tech bullitin a few years ago regarding corrosion due to electrolytic action,,,checking volts at heater core+rad and stuff,with all accy's on,,,they recomended to run ground straps from heater cores and rads,and other cooling system accys,,bad grounds were  causing premature corrosion,,,,,,
