General Information => Troubleshooting => Topic started by: Ortho Stice on July 20, 2014, 01:45:24 pm
Title: '83 Quantum TD runs away (but then comes back)
Post by: Ortho Stice on July 20, 2014, 01:45:24 pm
(http://i16.photobucket.com/albums/b36/igneousfaction/photo_zpsdded6a77.jpg)
Hello everybody, I've heard it said that these forums are where the most hardened of VW diesel-wizards hang out and so I come to you with some questions. To get it out of the way, I have read and searched quite a bit around here and that's all been very helpful.
I bought a Quantum TD wagon off some kid last month who didn't know a thing about cars yet who thought he could daily-drive a 30 year old VW. It runs and drives and really all I noticed on the test-drive was that it smoked a lot, had no exhaust left, and needed serious attention paid to the brake system. But it started right up, held an idle, everything (except the A/C) worked, and it was inspected so I took her home.
Now here's the thing; he mentioned that the throttle would hang up and said he was told the cable needed to be replaced. Upon taking a closer look, I discovered that it's not that the throttle hangs up, it's that once the engine gets farther up into the revs (around where it starts making meaningful boost) it starts to run away. If you hold the throttle lever at about halfway it'll start to run away slowly at first and then take off towards redline. Here's the thing though, if you let go it will hang for a second or two and then wind back down to idle no problem. In my searching of runaway problems I wasn't able to find anything like that mentioned in other threads.
So at first I thought I'd check to see if the turbo was the culprit; but, with the boost hose unhooked from the intake it still does it. It'll do it with the oil filler cap and vc breather both off, too.
Anyway, I'm not really looking for a "OMG WHAT DO I DO" type of thing here, moreso I just want to bounce ideas of y'all. So what are your thoughts? I'm inclined to think that well, maybe it's not oil after all? Maybe the pump or injectors are dropping too much fuel in there and it starts to run away but then when you cut the fuel it burns off the excess and then winds back down? We just pulled a running 1.6l (well it was before the headgasket blew, but fuel-wise it was good) out of a Rabbit that'll be getting a TDI soon and I thought I might swap the injectors over and see what happens and then swap the pump over (it had a turbo-pump on it) over and see if that makes a difference.
If it is oil, where's it coming from? Down the stem seals? I haven't done a compression test but if you pull the cold-start advance lever and glow the plugs it fires right up at the first touch of the key when cold and has no problem starting when hot, either.
Title: Re:
Post by: vanbcguy on July 20, 2014, 05:25:23 pm
You could have a sticky pump. If the governor assembly is sticking it can cause what you are describing.
Might be worth starting with either a diesel purge or ATF soak for the pump.
Title: Re: '83 Quantum TD runs away (but then comes back)
Post by: libbydiesel on July 20, 2014, 06:12:35 pm
It sounds like the max fuel screw is in too far.
Post by: Ortho Stice on July 20, 2014, 10:32:46 pm
Yeah I'd read that too much enthusiasm with that screw can lead to this kind of thing. But the anti-tamper collar is still in place...
I'll try the old ATF purge and see what happens. Then swap injectors, then swap pumps. I feel pretty confident that I'm burning diesel and not oil. Well, at least not more oil than usual.
Post by: libbydiesel on July 21, 2014, 06:33:14 am
Does the pump have the fast idle cold start or just the timing advance version?
Post by: Ortho Stice on July 21, 2014, 06:58:50 am
I don't know, it has the pull handle on the dash that moves a lever on the bottom engine-side of the pump through an, about, 45 degree rotation.
Post by: libbydiesel on July 21, 2014, 07:40:48 am
Does the back of the pump have this vertical rod running to the upper seesaw lever from the cold start, or does it just have the cold start lever at the bottom?
What rpm is it idling at?
Post by: Ortho Stice on July 21, 2014, 07:58:56 am
Nope just the cold start lever. And I don't have a tach so it's hard to say. When the cold-start lever is pulled it sounds "right" which should be around 800rpm, no? Maybe I've been pushing the lever in too early, but once it's warm it seems a little slow and rough.
Post by: fatmobile on July 21, 2014, 04:11:38 pm
 Smoked alot eh?
 What color?
Post by: Ortho Stice on July 21, 2014, 06:37:52 pm
Smoked alot eh?
 What color?
Bluish-grey. I ran some ATF through the pump until the return was pumping out only red and I'll let that sit for a few days and see what I loosen up, if anything.
Post by: libbydiesel on July 22, 2014, 06:59:56 pm
The injectors can make a big difference.  They can both cause the rpms to hang and make the idle sound lower than it is.  I had a somewhat sketchy set in a vehicle of mine and the idle had to be up near 1,000 to keep the rattles at bay.  It did not audibly sound overly high idle in fact, if anything, it seems lowish.  With those injectors and the idle set at that point it would hang the revs slightly.  With the injectors changed to fresh nozzles with the break pressure very close together the same engine can idle at 750 with less vibration that it had @ 1,000 with the old injectors and audibly seems like a very similar idle.
Post by: Ortho Stice on August 23, 2014, 10:29:55 am
Well I'm back from tour and got back into the Quantum these past few days. After a month of sitting with ATF, I fired the car up and it started no problem but... still ran away the same as it always had. And then I noticed a pretty serious fuel leak from the pump head. Like almost slightly open faucet level of leak, haha.
So anyway, yesterday I pulled off that pump and threw a known good pump on that we had lying around. I used the diesel timing tools to lock everything up and put the new pump in the same position the old one had been in. Pulled fuel up to the pump and then started cranking it over. So it will crank and then fire and then immediately die.
Any new thoughts?
Post by: Dakotakid on August 23, 2014, 01:09:29 pm
Yeah, paste the footfeed to the floor or hold it wide open while you crank it over. Are you doing this?
Post by: Ortho Stice on August 24, 2014, 10:45:56 am
Well a couple of things happened since I posted; While cranking with a friend watching he pointed out that air was getting into the fuel line (probably the original hose between the filter and pump) so I replaced that with some fresh hose and hose clamps. Primed the pump again and cracked the injectors and number 3 refuses to get wet.
So now I'm thinking that even though I was pretty sure this pump was good... maybe it's not? The rest of the injectors get soaked when cracked. I have yet to crack the #3 line at the pump head but I'll do that next. Perhaps I should just rebuild one of these pumps and injectors and start from square one.
Post by: theman53 on August 24, 2014, 11:04:14 am
How about just keep trying to get it running and work the air out of it.
Post by: Ortho Stice on August 24, 2014, 01:32:48 pm
Precisely what I ended up doing. After standing there confused for awhile, I thought, "hey, why not force feed this pump?" and so I grabbed one of the raptors we have lying around the shop and fed it diesel straight from the can at the lowest psi the raptor can do (should be around 7-10 I think). Anyway it fired right up but not in the nice, steady idle way that it used to but with much drama and clattering and sturm und drang.
So now, it starts right up but idles at, if I had to guess, between 1500-2000 rpms and throttle input does absolutely nothing. There was an actual pile of soot behind the exhaust after this drama. Okay so, my thoughts are this:
-Is the feed pump somehow throwing stuff off? I'll check tomorrow when I try to run it off the tank in the car (ran out of time tonight).
-Did I somehow slip the belt on the crank pulley when putting the new pump on? The pump and cam are lined up as they should be, but I didn't check the crank figuring that it would be unlikely to move as I was working up top. Again, something I'll check tomorrow.
-I noticed that the anti-tamper collar on the max-fuel screw is missing from this pump; though it ran fine on the previous car, is it possible I need to pull back the fueling or something?
-Is the pump in need of serious advance or retard?
Like I said, experimentation will continue tomorrow. Thanks to y'all for being a springboard upon which I may bounce ideas.
Post by: Ortho Stice on August 27, 2014, 09:01:09 am
Okay, I've answered all my questions:
-No, the feed pump wasn't throwing anything off. I hooked it back up to the car's tank and it did the same thing.
-Nope, checked the flywheel timing mark and with the crank at TDC, the pump and cam are where they ought to be.
-Max fuel screw does nothing. All the way in, no change at all.
-Nope.
So it looks I have two bad pumps, though bad in different ways. As such, I plan to rebuild the original pump as it (at least) ran the motor. Hopefully in disassembling, cleaning, and rebuilding I can figure out what was sticking and causing it to run away.
Any suggestions on rebuild kits or is one as good as the other?
Post by: theman53 on August 27, 2014, 09:13:07 am
You make little adjustments to the max fuel. If you ran it all the way in you went the wrong way, back it out past where you had it.
Post by: Ortho Stice on September 29, 2014, 01:14:06 pm
Say gents, any recommendations on a rebuild kit for these pumps? It is definitely the case that neither of these pumps work as is right now so I'd like to rebuild my original pump and put it back on. Strangely, I can't seem to find a rebuild kit or something like that from my usual parts sources...
Post by: fatmobile on September 29, 2014, 04:31:17 pm
Try reindexing the accel lever to the shaft.
 One notch toward a little more fuel.
Post by: Kraftwerk on December 21, 2014, 01:54:10 pm
Did you ever realized what was going on? Have similar simptoms on my '87 QSW TD...
Post by: Ortho Stice on May 15, 2015, 04:42:38 pm
Hey sorry got wrapped up in other things (namely a $600 TDI Passat and my 300k mile 940). Well in short, sort of. I rebuilt the pump and it stopped running away. The little triangle weights that spin with the shaft were covered in weird surface rust / chemical scale or something. I took very fine sandpaper and rubbed all of that stuff off. I assumed that the crud was causing them to stick or something? Nothing else inside seemed as affected by rust.
Sadly, when I put it all back together I clicked the starter with the ip lock pin still in place... that sheared teeth off the belt and now I have terrible compression. It starts and runs but once you try and rev it it begins misfiring and smoking and generally sounding terrible. I assume one or more of the valves caught a piston after top and bottom came out of time with one another.
Also, and I wonder if anyone else has ever seen this: the injection pump pushed the seal for the top of the pump THROUGH the side of the top of the pump. Like broke a sliver of metal off and pushed its way through. Thankfully I have another pump head lying around, but damn. It's one thing after another with this car!
Post by: fatmobile on July 10, 2015, 11:08:14 am
I've had that top seal break the side off the lid,.. when I didn't trim the bumps in the seal enough.
