Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: caddy on August 11, 2004, 05:59:57 am
i have two project in the same time time.... :?
the first is my passat, because the engine is dead and i need it!
the other is my new toy! :D :D an eurovan 2.4d who need a 2.5tdi :D
on the 2.5tdi engine the pump turn on left side, and is a 11mm plunger.
i want to fit on it a turbo from an audi v6 tdi 180 hp. ( vnt ???? )
a mechanical pump, may be i have to make my own pump....
then a set of 0.216 or more to hit the 180 or may be 200 hp?but not need hp, i need torque.....
then if i found it the gearbox of the 150 hp eurovan for best speed,now i have the 102 hp one....
last week end i work on it , and i know now that i have more probleme than a 4cyl!!
1st : the pumpe can't turn on the braket , and we can't tune a static timming! so i could swap the braket by the 2.4d one.
2nd : the pouley can't adjust the timming too!
3rd : the pouley have a damper for low vibration and better timming .
welcome to answer or question .....
some news...
the puley of the cameshaft who work on the pump side don't have nay thing for "stop" rotation.
so i can adust timming by this way....
now i have to found a pump with a big drive shaft...for the special puley...
Caddy, un moment donné vas-tu mettre une pompe de TDI avec l'électronique pour upgrader ton setup? :?:
Juste une question comme ça. :D
ben le probleme est de trouver les pieces.... :cry:
un t4 c'est impossible a trouver dans les casse auto! :cry:
alors un systeme d'injection complet...
et puis je pense que le setup sera fige une fois que le t4 rouleras.
je veux du power, mais tout en etant raisonable. 8)
j'ai d'autre projet plus fun , toujours vw, mais plutot air cooled.(beach buggy) :wink:
In english guys.. please.. :wink:
Marc/
sorry..... :oops:
I'm a wild thread highjacker!!!!! :twisted: :twisted: :twisted:
Come on, Marc...it's at least partly English! :D :wink:
Funny guy! :lol:
yep!
i just found the mecanical pump that i need!
it come from a peugeot! the drive shaft is in 20 mm, and it's a machanical one!
just turn on wrog side, but i think it will be possible to change that!
some news will come soon. :twisted: :wink:
LOL-
Caddy, when it comes time for me to find a pump for my mechanical TDI project, I'll be sure to look you up, you seem to find EVERYTHING! ;)
Our choices are a bit limited over here in wonkerland... :D
keep us up on your progress, please. :)
84 Scirocco 8v
00 Camaro L36 M49
hello!
i just open the peugeott pump and compare the body with the 5 cyl one!
there is only one ( and important one) thing change on body when it turn on left or right side.
it's on the advance piston, the escape hole of gazol is on the wrong side for me in the peugeot pump, but it's not a probleme, usualy this escape hole return to the intake gazol of the pump.
i think i have to close the hold hole , and make a way on the other side.
photo will come soon!
sorry , soon in english because now the bed call me! :wink: zzzzzzzzz........
some picture from my work on it...
that's why i need to found a new pump body:
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/drive%20shaft.jpg)
i need a 20mm drive shaft , because the puley are not the same! the tdi one have a damper, and with a 11mm pluger i think it will be sure to fit it on the mecanical pump.
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/poulie.jpg)
so this is the peugeot td pump body with the 20mm drive shaft:
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/corp%20de%20pompe.jpg)
the lda and all the accelerator part is from a land rover pump.
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/pompe+enr.jpg)
i need to change the way of advance timing piston:
tdi (upside) and idi.
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/pistonavance.jpg)
this hole is for low presure gazol , and gazol go back to inlet gazol screw.
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/avance%201.jpg)
it must be on this side!
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/avance2.jpg)
i need to make a little hole and with a small hose make it back to the inlet gazol screw.
just for fun.... 1mm vs 8mm
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/11vs08mm.jpg)
came plate...
idi and tdi...
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/cameplate.jpg)
braket off idi is the biggest with the advance cable...
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/suport.jpg)
my special nozzles :
(http://membres.lycos.fr/mecatronik/pompe%20meca%20t4/collection.jpg)
sorry , soon in english because now the bed call me! :wink: zzzzzzzzz........[/color=red]
"so this is the peugeot td pump body with the 20mm drive shaft"
Aloha Caddy,
I'm trying to get educated on building myself one of these hybred mech. pumps for a 2001 A4/TDI engine. My interest is to repower my '87 Suzuki Samurai w/ the TDI mated to a Toyota truck trans & t-case. I already have the engine/tranny adapter. The problem is, my engine didn't come w/ the wiring harness, ECU, etc. My engine came from a 2001 automatic beetle, so it has the bigger 11mm pump on it, which is good! My original plans was to keep it electronic & source all the parts(used/new) from the '98 & '99 New Beetle.
Those two years(USA) didn't have the IMMOB. & from what I understand the instrument cluster wasn't needed to make it run properly.
But have now desided to go the mechanical pump route since I see quite a few post of building these hybrid pumps.
My question is, can the larger 20mm drive shaft from the TDI pump fit in a TD that originally had a 17mm one? Is it just a matter of changing out the bearing/bushings? Also, what about the bigger plungers, say the 11mm one into one that has a 8mm.
I have two pumps available, any of these worth looking at;
(1) from a 2.1L TD 4cyl. winnebagos. From what I understand, it's the same pump used on the peugeots(VE style pump) also. I'm still waiting to hear from the seller to get the Bosch# to see what size pump it has. I believe they had 8mm, so if that could be changed out to the 11mm that woild be good!
The other pump is also a VE pump. However, it's from a cummins 6cyl., Bosch#0-460-426-184. The six digit says that this pump has a 12mm plunger. Just wondering if the head could be changed to the vw 4 head. If it could, I think this pump would be able to give the highest performance for a TDI. I'll try to post a picture of it.
Please, any comments, suggestion will be greatly appreciated!!!!!!
Thanks & aloha! ....renny
Well, not sure how to post the photos. :( ( It's stored on my computer.) I could e-mail it to you if you'de like!
Found a thread on the TDIclub forum. There is a member there, "Simon"/user name: "tdi rs" that builds these high performance hybrid pumps w/12mm plungers, etc. out of his shop located in England(www.centralvwaudi.com) Some are saying he is running a mechaincal TDI w/ the same pump & some other mods to get over 200 hp! :wink: If this is true, WOW! :shock:
The only thing stopping me from buying one right now, is the price :!: :!: :!: He sells them for 500.English lbs. each, that's like $962.USD-yikes! Better try & build one myself first :? & if that doesn't work out, then perhaps I can put in for overtime selling coconuts to buy one!
Yeah, Simon I think has the fastest TDI powered car anywhere right now- he's over the 250 hp mark, and in his A2 race car is close to 12 seconds in the 1/4 mile. He could probably provide you with a pump that's not quite so "race ready" for a little less.
Caddy has been able to locate a lot of pumps that would probably work with a mechanical TDI setup, him being "across the pond" helps with selection a lot more than what we can find in the States.
Also, the pump from a Cummins 4BT will work, but will need govenor tweaking (among other things) to overcome the 2700 rpm or so rev limit. :P
Hopefully I'll be undertaking a similar project for my Rocco within the next year or so.
That Peugeot pump sounds like it could be promising...
84 Scirocco 8v
00 Camaro L36 M49
Brendan,
Aloha & thanks! Will be e-mailing Simon to see what he would recommend for my set up. Yeah, from other threads on the TDI club, I hear Simon is pumping out alot of hp from his TDI powered race car. I would be "VERY" happy if I could get 130-150 reliable hp. from a mechanical TDI set up. Since my application or interest is for a 65% street & 35% trail rig, I am more so looking to gaining higher torque figuires in the lower to -mid range.
If I can get the straight scoops on the pump, turbo, etc. From what I understand, gotta use a waist gate turbo like a GT series(20 or 22) or T25R/T28R turbo, since the VNT turbos need the electronics to operate properly. Yeah, but what size, which one???? would be best to match the stock vnt or better yet an upgrade model to gain performance without getting into the internals.
Hey, just wondering why this forum seems so dead. :? Did everybody migrate to some where else(TDI Club) Also, notice on the TDI club some members add links that lead back to older post over here. Can't seem to find them anywhere here, are trhey archived some place else? :?
Anyway, thanks once again, aloha! ....renny
hye!
the engine is running now!!!
but the van can't , i need newest hose for the steering system.
the steering pump is not on same place in 2.5tdi. :cry:
the vw dealer tell me that cost is 300 eur for the two hose i need!!!
may be lnext month if i can buy it.... :cry:
ps: some of this board send me mail about it, i answer them soon, don't worry.
