For Sale/Looking For => Parts for Sale/Wanted => Topic started by: VTPSD on April 27, 2014, 02:19:33 pm
my 91 eco daily driver broke the #2 injections line (second cylinder from passenger side). I need that line or would buy all 4. Paypal ready. Thank you.
Before installing the new line, make sure that the bolt at the rear of the pump is tight. It's the #1 cause of broken #2 lines.
good thing to check, thank you!
anyone have these lines?
if ecodiesel lines are the same as td lines, if nobody has a used one to sell you, mk1autohaus has them:
http://www.mk1autohaus.com/Diesel-Fuel-Injector-Line-Cyl-2--Turbo-Diesel--Hose_p_6578.html
$30 for one line is a bit steep imho.
That guy on ebay who has a TD set that he isn't sure if it's missing line 1 or 2? it's missing line 2. he has two of line 3 iirc.
TD lines are not the same. The delivery valves on the eco are longer.
I have a set from when I upgraded to a TD Pump from the ECO pump. If I fanagle a way to keep the injectors out of the elements I can probably sell them to you.
would lines from a turbo pump fit my car?
like these?
http://www.ebay.com/itm/VW-Rabbit-Mk2-Golf-Jetta-Turbo-Diesel-Injector-Line-Kit-/360138656970?pt=Motors_Car_Truck_Parts_Accessories&hash=item53d9efccca&vxp=mtr
Ecodiesel lines are en route to you.
got the lines, thank you!
Just for future reference the bolt at the back of the pump was completely loose!
Good call burn_your_money!
