Engine Specific Info and Questions => IDI Engine => Topic started by: ToddA1 on April 20, 2014, 11:09:44 am
Title: Boost pin position
Post by: ToddA1 on April 20, 2014, 11:09:44 am
Hey, for those of you who have removed or had custom pins made, is there a way to position the pin in the aneroid to be more aggressive or docile?
I pulled the diaphragm and pin, as per the write up, to change the o-ring in the aneroid.  What I noticed is the pin's ramp is not centered on the base. It favors one side.  I was thinking that it could be rotated to change the fueling characteristics.
Has anyone ever experimented with this?  I figure if you had a custom pin made, you're already playing with the pin's orientation.
After changing the o-ring, I'm not sure why the write up has you pulling the diaphragm and pin.  The o-ring can be changed without opening and removing those parts.  Maybe for checking the diaphragm's condition and cleaning, but that's about it.
FYI, my hex plug must have been an odd size... 4.5mm, maybe. I ended up using a T-27 Torx and it fit perfectly.
-Todd
Title: Re: Boost pin position
Post by: 745 turbogreasel on April 20, 2014, 12:22:06 pm
steeper ramp = more difference between on and off boost fuel.
Title: Re:
Post by: vanbcguy on April 20, 2014, 12:38:48 pm
I've definitely played with mine a fair bit. There is a small punch mark on the metal ring on the diaphragm itself, if it is still aligned properly it can help with tuning. There is a small notch on the "front" of the LDA casting itself, when the punch in the diaphragm is lined up with the notch the LDA is set at its "steepest" setting. I usually turn it clockwise from there to reduce the ramp.
Post by: ToddA1 on April 20, 2014, 02:28:26 pm
Good info, especially the pinhole to notch info.  Gives a relative starting point.  Thanks!
-Todd
