Engine Specific Info and Questions => IDI Engine => Topic started by: audilvr on January 18, 2014, 10:26:35 am
Title: engine harness
Post by: audilvr on January 18, 2014, 10:26:35 am
anyone ever build their own engine harness? I'm looking to do this as mine is a bit hacked. wondering if anyone has any advice or maybe a schematic for a simplified harness. the only ad on's are a vdo oil pressure, vdo water temp, and a vdo volt.
Title: Re:
Post by: vanbcguy on January 18, 2014, 07:21:55 pm
If you are doing an IDI engine harness then you really only have a handful of wires. Glow plugs, fuel shutoff, 2 temp sensors, 2 oil pressure sensors... The alternator / starter only have a few each as well.
It's not particularly complex really as long as you are just staying with the engine wiring.
Title: Re: engine harness
Post by: audilvr on January 19, 2014, 04:24:02 am
that was my thoughts exactly, for how simple it is I'd rather have it fresh than a repaired mess. I'm having trouble locating the tool for pulling the pins out of the connectors though.
Post by: bbob203 on January 19, 2014, 06:18:17 am
unfold a paper clip bend it into a skinny horse shoe and flatten the ends with a hammer.
Post by: audilvr on January 19, 2014, 06:54:08 am
I was looking at this site for the replacement pins but I'm not sure which ones. i'm thinking 192175 might be the right ones for the fuse box connections
http://www.vehicle-wiring-products.eu/VWP-onlinestore/connectors/housings.php
Post by: vwroadkill on January 19, 2014, 07:08:51 am
ECS tuning has the terminal pin removal kit... shlum?s(sp?) not to expensive but it works..hope this helps
