Engine Specific Info and Questions => IDI Engine => Topic started by: jaed_43725 on December 09, 2013, 04:45:41 pm
Title: A/C Delete Q's.
Post by: jaed_43725 on December 09, 2013, 04:45:41 pm
I am doing at A/C delete because my A/C tensioner bolt broke and I planned on doing it anyway. So it was a convenient excuse. So I plan on leaving the alternator in the same place except it hangs down and I will use a turnbuckle for tension with the arm the alternator used to attach to. I came across 2 different part numbers (049903119L and 026903119B) for the pulley I need and not sure which is the right one. I did find the correct pulley on a car being worked on at Apex Tuning and that is where I gathered the information on what car the pulley would be on (92 Jetta / Passat 16V 2.0L).
So what I am asking is, is there a difference between the 2? If so which one is the correct one? Will my plan work? Is there a better (i.e. cheaper) way? Will those pulleys even fit on my alternator (85 Jetta TD w/AC (no P/S))? Is it better to get a different alternator with the correct pulley and add the tach connection?
Thank you in advance.
Title: Re: A/C Delete Q's.
Post by: fatmobile on December 10, 2013, 10:05:17 am
Check the FAQs.
 You have the right alternator, belt and bracket,.. pully info is there.
Post by: jaed_43725 on December 10, 2013, 12:10:53 pm
I checked them.  There was no A/C delete info.
Post by: fatmobile on December 12, 2013, 10:01:47 pm
 I couldn't find it either.
 Try "air conditioning" on vwdieselparts.com
 My username might help the search over there.
Post by: theman53 on December 13, 2013, 04:32:01 am
http://www.vwdiesel.net/forum/index.php?topic=32520.0
has this link in it...
http://www.vwdieselparts.com/forum/viewtopic.php?f=8&t=7018&p=42317&hilit=alternator+bracket#p42317
Which tells you this...
The pully I used for my swap came from the WAI catalog.
 Part # 24-2106, for the 1/2" belt
 or 24-2105 for the 10mm belt.
 Here's a lame pic of the same setup in my Rabbit:
which is the same as some pulley for a ford truck, I cannot remember the year. I bought one for 8.00 new at the local shop.
Post by: theman53 on December 13, 2013, 04:38:49 am
http://www.ebay.com/itm/2-V-GROOVES-PULLEY-USED-ON-FORD-DELCO-HD-ALT-/140814999163?pt=Motors_Car_Truck_Parts_Accessories&hash=item20c93a5e7b&vxp=mtr
This is for the 1/2" belt which is what I recommend if you are doing this with the MK2 a/c alt. If you look at his sale page, the ford part numbers and search that, you maybe able to find better prices.
FWIW the only thing I don't like is the fact that it has no keyway slot. I put mine on and have no issues right now, but if I do I am going to have a slot cut so I can use the factory woodruff key or key stock to make sure it doesn't move off there.
Post by: fatmobile on December 14, 2013, 12:00:19 am
 I get the pullys for $20 at the local alternator rebuild shop.
 That FAQ post needs a more searchable title including the words air conditioning.
Post by: 92EcoDiesel Jetta on December 14, 2013, 08:22:40 am
1. Get that double pulley, install it with no shims and the belt will line up.
2. Do not grind so you can use the same belt unless you enjoy a lot more unnecessary work. Just get a longer belt.
3. Do not use an aluminum turnbuckle. Mine stripped the aluminum and became useless. Find a steel one with no play in the threads if you want to use a turnbuckle.
4. Lastly, a turnbuckle on top pulling on the alt is easier to work on than pushing from the bottom.
I made a belt tensioner with angle iron brackets and a long bolt after  the aluminum turnbuckle failed and have no more alternator problem since.
Ever
Post by: fatmobile on December 19, 2013, 10:53:32 pm
 Grinding the bracket allows a shorter belt and less flapping for the same tension,..
 and I don't like the way it sticks out so far.
 Less room for belt tensioning without hitting the radiator, a real problem when doing this on a MK1, not so much on the MK2.
