For Sale/Looking For => Parts for Sale/Wanted => Topic started by: bbob203 on November 22, 2013, 03:28:47 pm
Title: FEELER FS 1992 Passat Wagon m-TDi
Post by: bbob203 on November 22, 2013, 03:28:47 pm
Gauging interest and considering selling my B3 Passat wagon Wanting something newer. 1992 body with 208,xxx miles on it white with peeling clear coat and a few dings here and there overall not rust on the car just browned dings. I converted the car last year with a 1z motor present time it has about 255,xxx miles on it. Overall a great car I drive it everyday frequently 100 mile 1 way trips and just drove it to Arizona in October and it performed great the whole time. This thing can haul a lot of stuff. All the windows work and nothing leaks including the sun roof. The interior is black and clean. Window tint is peeling. Ill put some pictures up tomorrow.
Boost, EGT, Oil water/temp switched, and oil psi guages.
Pd150 intake w/ race pipe.
Rebuilt k14 with 16-17k on it. 18psi w/ MBC.
   -Ebay special braided oil feed and oem oil drain brand new.
Veg .216 nozzles. injector bodies rebuilt by DBW set at 235 bar.
12mm cummins 4bt pump built by libby same mileage as the turbo. This was a brand new pump not rebuilt.
2.5'' FMIC from ebay.
MK4 shifter setup w/ TT short shifter and 42 draft design bushings.
CTN trans 140k on it per previous owner.
VR6 pressure plate with TDi disc installed new at time of build.
Conti timing belt ina rollers and tensioner done at build 16-17k on it.
Cruise does not work and needs troubleshooting and probably new switches.
B3 AAZ cluster gas and temp guage don't work. Tach speedo work great.
Rabbit spin on filter.
Ac hooked up but needs troublshooting.
Windshield has a horizontal crack midway up passenger a-pillar terminating slightly past the middle.
Bilstein HD struts up front new bushings/bearings.
Facet posi flow lift pump.
Rear shocks probably need replaced and the springs are little tired.
R32 front control arm bushings.
Front suspension has been a tinge noisy lately haven't looked into it much though and the glowplugs (all tested and work) still haven't been hooked up but it starts great with the 1000CA battery I have in there.
5,000 obo I have at least 7k in it but Didn't save any receipts really so no proof but my word.
