General Information => General => Topic started by: bbob203 on November 18, 2013, 04:09:11 am
These look to be the same size as the factory fittings. Posting the think for myself and for others.
http://www.ebay.com/itm/Turbo-Water-Pipe-M16x1-5mm-Garrett-T3-TB03-SAAB-VOLVO-Nissan-R31-R33-1-2-Hose-/380768712813?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a795786d&vxp=mtr
wonder if that is the same as the IP banjo?
IP banjo is the same as the oil feed line on AAZ/AHU/1Z engines.
Why use a banjo at all? I converted mine to AN fittings. MUCH nicer.
I was thinking this may work for the DRAIN banjo fitting on the back of the block but i think its to small.
Once again, why use a banjo on the drain??? Use an AN hose.
Here are the parts you need.
(http://img.photobucket.com/albums/v648/stewardc/100_1135_zps639ad8b3.jpg)
