Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: One_punchmachinegun on November 03, 2013, 10:25:59 am
Title: Cam sprockets.
Post by: One_punchmachinegun on November 03, 2013, 10:25:59 am
Hey really quick question. I was doing my dad's TB(alh) and the cam sprocket cracked, so instead of pay 80 bucks I checked if a 1.6 spocket matched up and they are identical. Do you think this is alright to do
Title: Re: Re: Cam sprockets.
Post by: One_punchmachinegun on November 03, 2013, 10:41:55 am
Identical other than the inner part of the sprocket. Same tooth count and size.
Title: Re: Cam sprockets.
Post by: RabbitJockey on November 04, 2013, 04:37:22 am
tooth count is definitely the same, the taper/press fit should be the same, but i have never worked on an alh to be able to tell you it will work.
Post by: One_punchmachinegun on November 04, 2013, 05:30:54 am
Yeah, I ended up just buying one. I will get all the measurements when I get the new one. I really think that they are the same. The ALH one design sucks, it's much weaker. It cracked because I didn't use the VW specific tool and I used my own sprocket puller. But I could only get on the outside of it and when I started to apply pressure the outer sprocket wheel came right off leaving the rest of the sprocket on the cam. I've never had issues with the older 1.6.
Post by: bbob203 on November 04, 2013, 05:36:21 am
I agree weal design also doesn't help when people crank them down to 60ftlbs to.
Post by: RabbitJockey on November 04, 2013, 06:10:05 am
Yeah people totally overtorque them, probably scared of the press fit.  I always just tapped them off with a hammer, a quick swift knock and they come right off.
Post by: theman53 on November 04, 2013, 06:15:49 am
If there was only a way to drill a hole in the plastic timing cover back side so you could do it just like a 1.6
Post by: libbydiesel on November 04, 2013, 06:36:58 am
Is that sarcasm?  There is specific spot cast into the plastic backing plate for drilling a hole and using a punch on the rim of the sprocket.  I have never had any issue getting them off that way without damage.  I make sure the mating surfaces do not have any oil residue by cleaning using brake-clean and then torque to 45 ft-lbs.  I know of more than one cam that slipped from the factory without ever having been loosened.  That leads me to believe the factory torque spec is too low.
Post by: RabbitJockey on November 04, 2013, 08:40:23 am
hmm thanks for the tip, ive been doing the 33 or w/e it is.
Post by: bbob203 on November 04, 2013, 08:43:27 am
I do 33 + a little extra
Post by: One_punchmachinegun on November 04, 2013, 10:19:59 am
Yeah same here. About 40-45lbs.
Yeah the thing was so on there I had to remove the cam to get it off after it had broke. Even then it wasnt easy. If I had to guess it was torque to 100. It was solid.
Post by: CRSMP5 on November 04, 2013, 11:33:20 am
id ask the dr diesel guy who made cams... if his cam fit a aaz and a tdi.. id say same..
yep plastic has spot to drill... hammer/punch.. no need for puller till pd that ive seen
Post by: One_punchmachinegun on November 04, 2013, 01:04:40 pm
Good advise right there.. thanks
Post by: theman53 on November 04, 2013, 04:14:03 pm
Yeah it was a bit sarcastic. I mean if you don't own a set of bits that will drill through the plastic you probably shouldn't attempt the TB job.
Post by: vanbcguy on November 04, 2013, 05:47:15 pm
Remember we had someone who was smacking the transmission end of the cam with a hammer trying to make the sprocket pop off the other end? Always good to make sure things are spelled out for the next guy...
Post by: bbob203 on November 04, 2013, 05:49:57 pm
I bought the metalnerd timing tool kit and the puller they supply is top notch Im hoping it will work on injection pumps to,
Post by: RabbitJockey on November 05, 2013, 04:58:37 am
haha, there are seriously some people who just need to put the tools down and back away from the car.  when i look at buying a car that is one of the things i look for: any clue that would lead to think a total amateur or hack mechanic ever touched the car... you know wood screws and wire nuts that type of stuff.
on face book i joined the group PA Dubbers.  the questions those kids ask are really sad, last night one guy was asking how to remove the v belt from his mk2.  like dude u need a friend who can start teaching you stuff, you don't need facebook.
Post by: One_punchmachinegun on November 05, 2013, 11:02:04 am
Haha, yeah. I haven't learned my lesson yet with buying cars. I always end up getting a car that some hack artist had, and I repair it. This mk2 I'm driving now when I got it 70% of the coolant hoses were garden hoses, the interior and engine wiring harness were jacked.. and much much more... Sometimes I just don't get people. Other times I understand why some might "make" something work, but other times it really just comes down to safety issues.
V-belts? They are a piece of cake.. when I first started working on cars I just jumped into it. Learned a lot that why. Often it was at the expense of a mistake, sometimes it would be before the mistake would happen which was always good.
Post by: RabbitJockey on November 06, 2013, 08:46:58 am
Yep, i earned my fix a hacked car merrit badge already, no thanks on another one.  if i see one hint of that type of *** i pass.
Post by: One_punchmachinegun on November 06, 2013, 05:21:36 pm
Just as an update and info for another person looking for similar info, the 1.6 sprocket does NOT work. It sits to close to the head. It doesn't have the same offset. Thanks for the help guys.
