For Sale/Looking For => Parts for Sale/Wanted => Topic started by: srgtlord on October 14, 2013, 05:51:40 am
As the title states I need a full set of 16 chrome hubcap clips as the ones I found online manufactured by RPM do not fit and fall out...
Does busdepot sell good ones?
I assume they will be the same useless clip produced by the company RPM. I purchased 16 useless clips manufactured by RPM from ecstuning http://www.ecstuning.com/Search/SiteSearch/321601175b/
The picture is deceiving. The problem is the little tab on the bottom is bent too far snd sits far too loose into the wheel and just falls off... When attempting to bend the clips back to where they are suppoose to be the tab breaks off. Looks to be a manufacturing error. I checked all over the net and it appears this is the only company supplying these clips and they all are garbage.
Anyways the clips I need look like this
(http://img801.imageshack.us/img801/9871/img4508e.jpg)
They are found on vw mk1's and 1985-1986 vw mk2's
I ended up with a set of those same clips from ECS and they are garbage indeed. I broke two and started to think differently. Ended up with two sets of rims instead. Snowflakes and some Riken ones for summer. Still have the clips and caps.
In that case I might just tack weld the little bastards to the rim
