Engine Specific Info and Questions => IDI Engine => Topic started by: JimEG on October 02, 2013, 06:00:59 pm
Title: AAZ - Root beer Syncro Vanagon
Post by: JimEG on October 02, 2013, 06:00:59 pm
Hi. New to the forum. New to the idea of a diesel Vanagon.
I recently picked up a "complete" 80k AAZ Turbo Tiico kit that was pulled from another Syncro for a 2.5 Suby swap. Included with the kit were an extra Sabb IC, extra good KO3, extra rebuildable KO3, new clutch and a bunch of other bits and pieces. I did not perform a compression or leak down test prior to removal(it had been pulled in the week prior to the sale). The PO sent me a video of it run - sounded "OK", but I am no diesel expert. The shop that did the swap said it seemed to run fine. At this point I am taking the PO word for it that the engine ran good and no issues. Anything I can or should do at this point to verify engine health?
The engine set up consists of this -
Tiico? adapter plate and starter adapter - powder coated white(I also have KEP adapter I could use, if I should)
Factory carries bars
AAZ
Sabb intercooler(with long plumbing to the passenger side vent)
New KO3 turbo
LDA? injection pump
Empi oil cooler w/fan
"bigger" injectors(should I verify anything?) I also have the stock injectors.
So now. Here I have this hulk of oil, steel and diesel hanging outside my shop.  What now?
I'd like to get your opinions and experience on what I should do prior to install(within a reasonable budget). I'd like to have it live long and provide as much power as it can without sacrificing longevity. I've spent many hours reading builds here and on Samba. I don't want to tear the engine down if I don't have to. I want to run it. I'm thinking bolt on improvements - new or different IC? Giles or other pump build? FAS carrier and exhaust? different turbo? water injection? or should I get out while I still can?
The obvious things I plan to do(thanks FAQ section) -
Clean and paint
Clutch pulley on alternator
Investigate crank/pulley syndrome
New seals and gaskets as needed
New belts
Gee Bee hoses
Gauges
I would also like to eliminate the AC compressor. How do I do this?
Vince Waldon glow plug pimp
SO WHAT WOULD YOU DO? THANKS!!! And I welcome PM's or input/proposals from any vendors or anyone in the diesel tuning business.
(http://images.thesamba.com/vw/gallery/pix/1117172.jpg)
(http://images.thesamba.com/vw/gallery/pix/1118897.jpg)
(http://images.thesamba.com/vw/gallery/pix/1118896.jpg)
(http://images.thesamba.com/vw/gallery/pix/1118895.jpg)
(http://images.thesamba.com/vw/gallery/pix/1118894.jpg)
(http://images.thesamba.com/vw/gallery/pix/1118893.jpg)
(http://images.thesamba.com/vw/gallery/pix/1118892.jpg)
(http://images.thesamba.com/vw/gallery/pix/1118890.jpg)
Title: Re: AAZ install advice - Syncro Vanagon
Post by: Gizmoman on October 02, 2013, 07:47:14 pm
No expert here, but I've been building my AAZ (2WD Westy) for over a year and this site has helped me through a lot of it.
Hard to tell from the photos but I'd start by removing the mounts and cutting off the weird stuff someone welded on to them.
As for the turbo, I've been told that the K14 is a better fit for the van but the K03 may be fine if your doing a lot of off-roading as I hear it spools almost instantly. Besides, it's new.
I also believe that "bigger injectors" are not necessarily better with the IDI engine. The pre-chamber is designed for what the stock injectors pattern is and messing with that is not recommended.
Welcome to the forum, lots of good heads here.
Post by: Toby on October 02, 2013, 11:43:28 pm
FWIW the motor hardly looks like it has just 80K miles on it. You will love the AAZ in a Vanagon. I have a friend with a 1.6TD Westphalia and it is a very nice rig to drive. He built a box on top of the engine hatch to clear the LDA. I have heard that there was a special pump with an LDA that would fit under the hatch, but I have never even seen a picture of one.
Forget the GP "pimp". Its just a bunch of high school silliness. At most the 4 wire bit is asking for trouble and would, at most, save you 20 minutes troubleshooting a bad GP. The system is dead reliable. It doesn't need to be fixed. It would be good, however, to transfer the load to a Ford starter solenoid. Just have the GP wire energize it.
Good luck on your swap. You will love it.
Post by: theman53 on October 03, 2013, 04:54:41 am
Toby, you are an expert mechanic and can service the 4 GP in 20 minutes, some of us aren't. There are some of us like me that cannot even begin to get the hood open and look at the GPs in 20 minutes, especially in the cold. While you may think it silliness, for me it is not. I cannot even get my hand behind the injection pump to get the nuts off the GPs as my hand is way too big, unless I loosen it or take it off, but that requires retiming the engine/pump. I usually have my wife thread the GP on/off to save time or just let the nuts fall and get new if I cannot find them. Even though the system does an OK job I think sometimes for people like me there is an equivalent or better way. I have had the fuse in the stock system fail several times, so just getting rid of that and adding one per plug is a benefit to me.
To the OP: it is not absolutely needed to change it, but when it fails then you can switch it like I did, if you want to save the time now.
Post by: JimEG on October 03, 2013, 08:00:15 am
Thanks for the replies. Most of the oil is from sloppy filter removal and a poor connection at the power steering pump, and i think the OP did some regular gravel road driving - maybe home. The engine came from Northern Idaho. At this point, while the motor is out I would like to do any work that will make my life easier down the road by doing so now.
Does anyone know about eliminating the ac? Is there another bracket I need to use, or part?
Is reusing the Sabb IC a good idea, or is there something much better now? Unless there is a big benefit, I'd rather not deal with a WAIC.
This IC install looks pretty good. Yes?
https://billwildenberg.shutterfly.com/vwvanagon/63
Is it worth sending the IP to Giles or the like, or is using the tuning method in the FAQ section sufficient?
See the oily banjo connection at the block for the turbo drain? Think that is the fitting or the copper washes leaking?
Any other tuning advice is appreciated. Thanks.
Post by: JimEG on October 03, 2013, 08:10:12 am
Thanks. Is that not an LDA on top of my pump?
Post by: vanbcguy on October 03, 2013, 08:16:27 am
It is an LDA, but it isn't the special one that will fit under the hatch without modifying the hatch... ;)
Actually I'm wondering if someone modified the engine mounts to drop it down slightly, as there isn't usually room for IC tubing over the top of the engine as shown in your first pic there...
Post by: bbob203 on October 03, 2013, 08:18:20 am
definitely an lda top!
Post by: vanbcguy on October 03, 2013, 08:34:40 am
Oh re: removing the AC: You can get a VR6 water pump pulley.  The result is the water pump will be driven by the serpentine belt rather than the V-belt.  You will need a shorter serpentine belt and a shorter v-belt for the power steering pump naturally.
Post by: JimEG on October 03, 2013, 08:57:22 am
Excellent.
Post by: JimEG on October 03, 2013, 08:58:17 am
Is it because I have a Syncro? I believe the engine sits lower in a 4wd.
Post by: CRSMP5 on October 03, 2013, 11:06:51 am
fyi... syncro engine sits lower then non syncro... so lda issue it lacks....
libby and giz are your sources... due to syncro id look at how libby did his auto tdi-m... as i do not think normal diesel bolts right up.. with out mods at least...
Post by: Gizmoman on October 03, 2013, 04:56:58 pm
FWIW, My AAZ has an LDA and fits under the lid no problem. My engine is at 50* and there are 1/2" spacers between the plates at the ends of the mount bars where it attaches to the frame rails.
Also, my pump is a 1.6 but it's been gone through by Giles and he said it will do just fine on the 1.9.
Post by: JimEG on October 03, 2013, 05:49:15 pm
Ok. Do you think the Giles tune on an already healthy pump is worth the money?
Post by: libbydiesel on October 03, 2013, 06:37:05 pm
FWIW, swapping out an AAZ to install a 2.5 Subaru engine sounds like a downgrade to me.  I haven't driven the 2.5 but I've driven a 2.2 Subaru and my tuned 1.6TD did better.  In stock form, tho, the AAZ is de-tuned fairly significantly.
The syncro drive train sits 1-1/2" lower than the 2WD.  Regardless, even with 100% stock diesel mount geometry on a 2WD Vanagon, the aneroid on the injection pump does not protrude above the tops of the ribs of the engine lid.
Here is a pic of the engine lid of an AAZ conversion that I did to a 2WD Vanagon:
(http://i13.photobucket.com/albums/a269/libbybapa/AAZ%20Conversion/100_1692.jpg)
I cut out a rectangular section of the lid and used a piece of sheet metal to cover the rectangle.  The sheet metal is resting right on top of the ribs and so raises the lid the thickness of the sheet metal (<1/16").  On a syncro there would be enough extra space to add another 3/4" of sound insulation to the bottom of the stock lid before there was any interference...
As far as bolting up to a Syncro, yes, using the tiico adapter plate (or the diesel vanagon bell housing on the syncro trans) it will bolt up fine @ 50°.  I'm not particularly familiar with the Tiico adapter so I can't comment on whether or not it is better than the KEP.  I'd be tempted to go to the stock diesel-vanagon bell housing.  I'm also not familiar with the starter that comes with the Tiico kit.  Will it crank over the AAZ (400psi+ compression) fast enough?
Get rid of the long plumbing of the Saab intercooler.  Why did they place it on the passenger side?  That long run adds lag with no benefit.  It's better to locate the air filter to the passenger side because you would not be adding lag on a long run from the air filter.  You'd just need large enough diameter tubing to be sure it wasn't restrictive.  If you go with a d-pillar air-to-air system, don't vent it into the wheel well area like that.  Everyone who I have talked to who has done it that way has had mediocre results at best.  The d-pillar vent and wheel well area are both high pressure areas and so opening the d-pillar to the wheel well effectively stops airflow through the d-pillar.  The engine compartment, on the other hand, is low pressure and so venting the air into the engine compartment results in better airflow and a more effective air-to-air install.
(http://i13.photobucket.com/albums/a269/libbybapa/AAZ%20Conversion/100_1726.jpg)
(http://i13.photobucket.com/albums/a269/libbybapa/AAZ%20Conversion/100_1729-1.jpg)
You might consider an air-to-water intercooler instead in order to keep the oil cooler on the pass side d-piller and the air cleaner on the driver's side d-pillar.  A well balanced air-to-water system will do a better job cooling the charge air and will add less intake volume (less lag).  It does add some cost and complexity, tho.
The pics show factory carrier bars, but the left one has been cut and welded.  It looks like that cut and weld on the DS would raise the engine.   ???
K03 turbo is very small.  It becomes an exhaust restriction at higher rpms even at stock boost pressures.  15 psi on a K14 is noticeably more power.  On the good side, tho, it is insta-boost and so gives decent off-the-line performance which might be more desirable in a syncro than top-end performance.
Post by: JimEG on October 03, 2013, 07:50:05 pm
Thanks for the photos and feedback.
I'm glad to hear you consider the 2.5 a downgrade. I really want this 1.9 to perform well, as I'd prefer to be burning diesel.
I noticed the cut and weld on the carrier bar as well. Not sure why. It does look like the exhaust wouldn't clear if it weren't modified. Maybe that is why. This set up came right out of another Syncro, so it should bolt right back in without any mods.
I am considering swapping some of the existing parts out to some FAS parts. I'm still evaluating engine condition and costs and then need to consider the priorities and budget.
What is the acceptable compression range for this engine? How much effect will not having it warmed(it is out of the van) have on the readings?
Post by: vanbcguy on October 04, 2013, 06:29:31 am
Compression should be over 400PSI, anything less than that and it would be considered "worn".  It will probably run down in to the low 3's but starting gets progressively more difficult.  A "fresh" engine should be around 500PSI.
Compression is usually higher warm, but it should be able to make 400PSI cold.
Post by: libbydiesel on October 04, 2013, 06:46:30 am
Cold compression check can give false indication of issues.  Sometimes cold a lifter will have bled down and not pump up very quickly.  The result is what looks like a low compression cylinder.
Post by: littlejim on October 04, 2013, 06:52:02 am
Hi
Its a common swap on this side of the pond, it may be slightly more difficult as you don't seem to have access to as many parts in the scrap yards (I think you call them bone yards)as we do.
Take a look at the "Brickyard" web site, scroll to the Diesel upgrade section and enjoy a couple of hours reading with a beer.
http://www.brick-yard.co.uk/forum/t3-diesel-upgrades_forum21.html
good luck
Post by: Syncroincity on October 05, 2013, 05:31:14 pm
What is the starter motor location with this setup? One big stumbling block on a Syncro using stock VW mounts & bellhousing is you need a diesel-specific fuel tank, because the starter is on top of the trans rather than on the side as on the WBX.
Post by: JimEG on October 05, 2013, 09:28:37 pm
Adapter plate. No clearance issues, apparently - it came out of another Syncro.
Post by: JimEG on October 05, 2013, 09:36:19 pm
Hi
Thanks for the link
good luck
Post by: JimEG on October 06, 2013, 10:06:57 am
How many HP are these good for?
(http://images.thesamba.com/vw/gallery/pix/1120154.jpg)
Post by: Gizmoman on October 06, 2013, 10:17:48 am
Looks like they double it - great find!
Post by: JimEG on October 06, 2013, 04:59:05 pm
EBAY -
http://www.ebay.com/itm/260529542732?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Found them from another AAZ post on Samba
Title: Re: AAZ - Syncro Vanagon
Post by: JimEG on October 06, 2013, 05:21:37 pm
Productive day today, thanks to some help from Zeitgeist and what is most certainly the coolest compression tester EVER. Moto Meter. German, of course.
(http://images.thesamba.com/vw/gallery/pix/1120374.jpg)
After determining the #8 jumper cables were too puny to turn the engine effectively, we engineered some hard wired #4 directly into the dual batteries in my F250 diesel. No voltage drop now!
(http://images.thesamba.com/vw/gallery/pix/1120371.jpg)
(http://images.thesamba.com/vw/gallery/pix/1120370.jpg)
Compression results appear to be good. Yes? Cold engine. Been sitting for a couple weeks. Not much oil in it. 410, 405, 415, 377. The Bentley calls out 363-450 in a new, warmed engine and a minimum 276 with a difference of no great than 73 between cylinders.
(http://images.thesamba.com/vw/gallery/pix/1120373.jpg)
Some questions.
What is the make on this oil filter adapter and is it thermostatically controlled? It was connected to cooler with fan.
(http://images.thesamba.com/vw/gallery/pix/1120375.jpg)
(http://images.thesamba.com/vw/gallery/pix/1120376.jpg)
How does this rear main seal look? Doesn't appear to be leaking. Looks like it as changed recently.
(http://images.thesamba.com/vw/gallery/pix/1120377.jpg)
This dipstick looks like it has had some soldering done to it, and it is not firmly connected to the block. Any replacement or repair recommendations?
(http://images.thesamba.com/vw/gallery/pix/1120382.jpg)
Here it is now. Ready for a little more tear down and then lots of Simple Green(or oven cleaner as a local mechanic recommended). Yes, I will be collecting the run off from this one.
(http://images.thesamba.com/vw/gallery/pix/1120378.jpg)
Title: Re: AAZ - Root beer Syncro Vanagon
Post by: Gizmoman on October 06, 2013, 05:49:23 pm
I believe that is the same adapter I purchased from Summit Racing. If it is, then yes, it is thermostatically controlled. There's a bi-metal spring inside that expands when it gets warm, restricting flow to the return port and forcing more oil to the cooler. I ended up getting a remote one which is more like a radiator thermo valve - seemed a bit more positive and would flow better.
Post by: JimEG on October 13, 2013, 08:05:06 pm
Moving along. Cleaned up and in the shop now. Zeitgeist talked me back down from the edge earlier - the timing belt/crank pulley tear down had me quite sketched out. I've resealed gas tank, tore down and rebuilt an entire front end of a Van,  but for some reason the timing belt situation was intimidating me. Maybe its the thought that if I eff something up my engine could be destroyed(ish). So, Zeitgeist will be back with some fancy tools referenced in the Bentley and I in the meantime pulled what I could.
Here are some pic's and some questions.
Steamy. I had my plumber add an exterior hot water outlet when I renovated my 1916 home. And, tankless water heater - I never run out!
(http://images.thesamba.com/vw/gallery/pix/1123007.jpg)
This sucks. There is a good welder in town. Im hoping he will look at this and say "no sweat".
(http://images.thesamba.com/vw/gallery/pix/1123006.jpg)
My engine's first language is...Spanish?
(http://images.thesamba.com/vw/gallery/pix/1123005.jpg)
This is the box for the nozzles that I believe are in the engine. Does that part number look correct for this engine? The PO stated the motor had "bigger injectors" in it currently.
(http://images.thesamba.com/vw/gallery/pix/1123004.jpg)
What does this do?
(http://images.thesamba.com/vw/gallery/pix/1123003.jpg)
Engine serial number.  - 028103021BE.
(http://images.thesamba.com/vw/gallery/pix/1123002.jpg)
And there it is, for now.
(http://images.thesamba.com/vw/gallery/pix/1123001.jpg)
Post by: Gizmoman on October 14, 2013, 05:47:47 am
Lookin' good Mr
I'll let the IP experts explain the tube. One bit I would definitely change is to remote mount the oil filter. Changing it on a 50 degree layout without making a mess is tough. If you decide to head that route, you might install a cooler as well. Some folks run one in front but I opted to tuck mine up in the frame. I suppose if I was going to go off road, I'd have gone with the "up front" mounting.
The WAIC cooler is forward, oil cooler behind.
(https://lh4.googleusercontent.com/-BLwMBW_qh04/UlP_QWMdbXI/AAAAAAAACKU/EDCPvkbJTWc/w983-h737-no/DSC00644.JPG)
I ended up removing the water/oil pre-heater chingus as I had heard horror stories of it leaking oil into the water. Instead I installed a thermo-valve - also remote mounted.
(https://lh5.googleusercontent.com/kmDPfgeDUcyXUlMyt8vLfew5JRelSqDMPSM0IuvgWac=w257-h192-p-no)
I envy your assistance from Zeitgeist.
Post by: TylerDurden on October 14, 2013, 05:57:04 am
What does this do?
I'm no expert, but  the book say:
That is a feature to de-activate the LFB ("Load Dependent Start of Delivery").
(https://lh4.googleusercontent.com/-KsZ9kxvfXDY/UU2-uEfKZxI/AAAAAAAABFs/Lhc5d90Tpfo/s800/ALFB.png)
(https://lh6.googleusercontent.com/-gjZTpWq7mq4/Ulvphxd_IxI/AAAAAAAABXU/3t0YZ-k6uuU/s800/p54test.png)
Post by: Zeitgeist on October 14, 2013, 08:22:13 am
So I gather this LFB solenoid is triggered by a relay receiving a signal from a 60C temp switch?  I assume the temp switch is located on the coolant neck either on the side or end of the head.
Post by: JimEG on October 14, 2013, 07:33:11 pm
And so, by having it disconnected the solenoid is open leading to increased HC emissions when cold. Activating this solenoid(via temp switch) would decrease HC emissions when cold, and then would open the solenoid once warm restoring it to its "normally open" state. So, if I care about polluting, this solenoid will need to find temp switched controlled power. Is that correct? It was not connected under the PO. Is
Thanks for the diagram and explanations!
