General Information => Troubleshooting => Topic started by: bbob203 on September 13, 2013, 05:10:55 pm
Title: Click click click ugh..
Post by: bbob203 on September 13, 2013, 05:10:55 pm
Put a trans into my mk2 today and go to start and click click click. Starter is good engages and spins on the bench and engine spins freely with a wrench on the crank bolt. The bushing looked good in the trans.  ??? ??? ???
Title: Re: Click click click ugh..
Post by: TylerDurden on September 13, 2013, 05:12:57 pm
Check the engine ground?
Post by: 8v-of-fury on September 13, 2013, 05:36:38 pm
Yeah guy, no amperage.
Post by: bbob203 on September 14, 2013, 06:23:04 am
clean and lube with dielectric grease it is then.
Post by: fatmobile on September 18, 2013, 10:59:25 pm
 Click/hold for a long time then feel for the hot connection.
Post by: air-cooled or diesel on September 21, 2013, 07:18:03 pm
if its amps -the engine/tranny need 1 big ground to batt, 1 big ground from engine to body, you should have 2 smaller grounds from batt(ground) to body, I also like to run 1 more big ground from tranny (ground point for 1st big ground wire) to alt bracket/arm, the body ground wire I said run from this point; I like to run to fuel filter mount.
the 2 smaller wires from batt(ground) to body are important
I also like to run 1 more ground from batt (2 smaller wires, same size as 2 wire ground to body) to a different body location.
make sure all metal on body is clean, bare metal(you can also after this, seal the points.). make sure nuts/washers are clean/or new. use plenty of washers! for more contact area(like at least 1 per contact point.).
check voltage drop, I think its burn money has a link for checking for voltage drop, its on this web site anyways.
