General Information => Troubleshooting => Topic started by: homerj1 on August 08, 2013, 01:39:47 pm
Title: temp fix for pinhole in injector line.
Post by: homerj1 on August 08, 2013, 01:39:47 pm
Hello,
I have a small pinhole in one of my injector lines on my 1.6td.  I also have a 12 hr drive home on Sun.
I was thinking of splitting a 2 in long section of small  tubing, then a larger dia  fuel line over that, then some triden clamps.
Will this work?
thanks
Aivars
Title: Re: temp fix for pinhole in injector line.
Post by: CRSMP5 on August 08, 2013, 01:52:49 pm
no... i used my tig to fix one though 1 time... but i spliced 2 lines in a solid area.. pin hole = thin so no strength left..
Post by: homerj1 on August 08, 2013, 02:50:52 pm
Maybe, I wasn't clear.
I was going to put the 2 layers of diff. dia rubber line ON TOP of the steel injector line, not use it to connect the 2 parts of the line.
Sort of like a Band-Aid.
or else it will be a leaky smelly drive home :( :(
Post by: Toby on August 08, 2013, 03:42:42 pm
Do you really think that hose clamps are going to hold 1500 psi? Tig it up or get a new none. No easy patch on those.
Post by: libbydiesel on August 08, 2013, 04:18:28 pm
2,000 psi will shoot through the rubber.  Get another line.  With it leaking your engine is not going to run well.  Call local repair shops to find out who hoards the vw diesel stuff.  In a pinch, the early 80s Merz 300 series is the same length and ends and can be bent to fit.
Post by: TylerDurden on August 08, 2013, 05:40:32 pm
I flowed a bit of bronze using a mapp torch on a pinhole and it's fine for years now.
As a temporary fix, a bit of solder might be fine.
Consider 2000psi... how many pinholes in a sq-in...?  100x100?  maybe more.... say it's 2000.
That's 1lb of pressure, if you are sealing the area of just the pinhole.
Post by: TylerDurden on August 08, 2013, 05:44:08 pm
P.S. if the hose & clamp bit drip, that's still better than a pinhole misting fuel in the engine bay. (BTDT)
Post by: 8v-of-fury on August 08, 2013, 05:45:34 pm
yeah lol, 2000 lbs per square inch, not per each individual measurable piece of the line.
I would think a rubber fuel injection line, rated for some pressure.. clamped real good right at the pinhole should work as an extreme temporary fix.
Post by: homerj1 on August 08, 2013, 05:54:25 pm
I was thinking about the pressure in the injector return lines.
Although the surface area responses pin hole vs  an actual sa of I sq inch,  makes sense. I'll try that tomorrow like a bandaid
Just in case, I'm currently in Montreal, so if anyone had a suggestions for injector line sources in the city, it would be appreciated.
thanks
Aiva
Post by: 8v-of-fury on August 08, 2013, 05:57:56 pm
I have a few sets of lines.. but that doesn't help you right now..
Post by: homerj1 on August 08, 2013, 06:00:47 pm
 :) Thanks anyway.
 I also have a set at home that I thought about bringing on the road trip   :-[
Post by: bbob203 on August 08, 2013, 06:40:03 pm
maybe jb weld wrapped in rubber hose?
Post by: 8v-of-fury on August 08, 2013, 06:59:11 pm
I like the idea.. way better.
Post by: libbydiesel on August 08, 2013, 07:24:48 pm
Rubber fuel injection hose is rated @ 100 psi or so.  That means that a pinhole location that is 1/2000th of a sq-in may only be producing 1psi, but the rubber fuel injection hose is only rated to withstand 0.05psi / 1/2000th of an in^2...  It just as under-rated as if you tried to run rubber fuel injection hose the whole way.
Post by: CRSMP5 on August 08, 2013, 07:30:56 pm
yes hihdsight 20-20.. always in spare on road trips.. i borrowed themans tdi ones for my cali trip... got a set now too... but rember, tig, brass, solder... do not fill the pipe with it.. leak better then improper flow too...
i tried one of those brass couplers on my pin hole 1 first... fail...so triied tig... :P
Post by: libbydiesel on August 08, 2013, 08:51:02 pm
Yes, it's only 1lb of pressure, but it's only acting on a pin sized area.  To make a very apt analogy, just imagine setting a 1lb weight on top of a pin poking into a rubber hose and then removing it and then setting it back on the pin 1,500 times per minute.  How long before that pin pokes through the piece of rubber?
Post by: TylerDurden on August 09, 2013, 06:26:30 am
I'm not convinced that's a very apt analogy...
Line pressure does not return to zero due to the delivery valves, and as the rubber deflects from fluid pressure rise, the fluid surface area spreads (as opposed to a metal pin).
With a band clamp around the hose at the point of the pinhole, I'd wager the hose's burst rating does not directly apply.
Post by: theman53 on August 09, 2013, 07:05:10 am
I think it won't hold well. I think the best bet is to try it and see. Better than nothing for at least a few miles. Since it is junk anyhow unless you are welding it I would JB weld over it and that will probably work better.
Post by: homerj1 on August 09, 2013, 08:32:32 am
Thanks for all the advice.
I actually hooked up with Caveman, and he fixed me up.  :)
Aivars
Post by: libbydiesel on August 09, 2013, 09:18:52 am
Now I want someone to try...  An apt analogy is always going to be somewhat different from the actual situation...  You are correct, line pressure does not return to zero.  Yes rubber will deform and as you say, the surface area will spread but that won't reduce the force, it will multiply the pounds of force applied by the added area.  It would reduce the misting in the engine compartment but I'm convinced it wouldn't hold back the leak.
Post by: Toby on September 23, 2013, 10:00:46 am
You guts need to brush up on your physics. 2000 psi is 2000 psi no matter how large an area it is acting upon. The pressure does not go down when you are applying it to a small area. Its still 2000 psi.
