General Information => Troubleshooting => Topic started by: Brianshayne on July 22, 2013, 08:07:03 am
Just started... Ticking sound, matches RPM...
Possibilities: I have an inner CV seal that I know is blown -- need to change it. Could it be this?
One of the belts making a sound?
Lifter/internal engine? (Doesn't SOUND like the lifter tick on my old subaru -- not a bearing tick either, as far as I know)
Should I record the sound maybe?
You can eliminate option #1 (CV) if it still ticks in neutral.
Yup did that, was about to post. It almost sounds like a gasser injector click? A little more robust though
Went to go record. No tick.
ITS FIXED!!
I don't want to scare you but that is kind of what my precup did when it was about to fall out. If you notice loss of power up hills then I would bite the bullet and pull the head. If it runs fine then I wouldn't worry. It could just be the advance giving you a nailing sound.
ITS FIXED!!
My boss says this.. He is a douche.. haha.
It hasn't been present since this post. Weirrrd
Sent from my SGH-I747 using Tapatalk 2
ITS FIXED!!
my favorite thing at work is when people say whats wrong with it? and i just say it's broken.
i am soooooo funny.
you have a hydro or mech head? ticking -usually- indicates lifter or exhaust. if you have a mech head and know your way around your engine you may want to check valve lash. even on a hydro looking under valve cover can tell you a couple of things.
No clue what kind of head.
Sounded like a sticky lifter actually. Gone now though
AHHH, NO, IT'S BACK!
https://www.youtube.com/watch?v=M3-DrD1ylI8
i couldn't watch/hear video as I didn't want to register on another website,
but a ticking could be exhaust or lifter. if its hydro lifters it could be bad lifter or possibly need fresh oil. if its hydro lifters and lifters/cam lobes look good; if you haven't changed oil in a while, use a good engine oil flush and run at a fast idle(don't drive with flush in oil) and change oil/filter. if you use conventional oil, i use Castrol 10w-30 cj/ch rated. if you use synthetic you'll have to find some good quarts. maybe try a auto/diesel shop, or a german shop. i don't like the rotella, the Castrol is a step or 2 up from rotella.
hopefully this will help.
i think the first thing is to determine if the 'tick' is exhaust or possibly a lifter. and if its a lifter a visual inside valve cover is what i'd start with.
if you change oil use a good filter too. napa has decent filters(air and oil; and good belts too).
Sorry, I had it set to private. My mistake. Try now.
I'm running 10w-40 Rotella atm. Should I be running a lower weight? The clicking sounds exterior in the video, so maybe belts?
is your intake set-up tight and secure?
Yes. It's not the source of the noise. Car came with that -- planning on replacing it with a stock airbox soon.
Noise was GONE this past drive again. SEems to come and go.
Most run 15w40 if conventional.
I have a 1.6TD running 0w40 full synthetic. An AAZ running 5w40 synthetic, and a TDI running 15w40 conventional.
Yeah was mistaken, it's 15w
