For Sale/Looking For => Parts for Sale/Wanted => Topic started by: felipe1f on July 16, 2013, 03:02:42 pm
Title: wtb. vanagon diesel thermostat housing cooling flange. fair price.
Post by: felipe1f on July 16, 2013, 03:02:42 pm
I fixed the head in my vanagon and now the cooling flange is leaking,it has a hair crack but that is enough to leak.anybody knows if the
jetta diesel cooling flange woul fit the vanagon diesel?
thanks for the help.
Title: Re: wtb. vanagon diesel thermostat housing cooling flange. fair price.
Post by: the caveman on July 16, 2013, 03:36:26 pm
I think the only exception to the I 4 VW engines from 1980-1998 for the thermostat cover were Foxes. Should be the same as all the others. I'm assuming you have a 1.6 or 1.9 diesel and not a flat gasser !!
Post by: libbydiesel on July 17, 2013, 06:41:26 am
Vanagon style is different from most.  Jetta/Golf/Rabbit angle straight off the water pump and will run into the pass side mounting bracket.  I think Quantums may be the same as the vanagon.  The vanagon one angles away from the block @ a 45°.  I have one.
Post by: CRSMP5 on July 17, 2013, 07:00:04 am
he spoke.. said same thing i think too.. so ill 2nd it... go look/ask gizz on his aaz build he just worked on getting in a vanagon.. bet his pics will show..
yep...
(https://lh4.googleusercontent.com/-RMBs5aHptB4/Uan745__qcI/AAAAAAAABxA/CLiOn1oBzDM/s720/DSC00489.JPG)
so 45 it is...
Post by: felipe1f on July 17, 2013, 02:39:12 pm
Thank  you all for the info, I am going to get the one from LIBBYDIESEL.
