General Information => General => Topic started by: caddy on August 06, 2004, 02:57:26 am
Title: need a little help...
Post by: caddy on August 06, 2004, 02:57:26 am
hello evrybody!
i'm working on new project, tdi of course!
i buy an eurovan with a 2.4d blowed, so i buy a new engine for swap it, is a 2.5tdi, i have a lot of little thing to resolve.
first and the biggest: were can i find a pump body (mechanical) with a 20mm drive shaft, and who turn on the left side? do you have idea?
then i put the lda and the hydrolique head & rotor of the 2.5tdi ( original 11mm ).
then , the other probleme is the link cable to the tacho! the gearbox is not sams as the 2.4d, and i don't know if the cable existe.
thanks for all suggestions.
Post by: caddy on August 06, 2004, 03:09:05 am
i found this references for bosch pump:
pompe bosch....
5cyl l side
0 460 405 025
0 460 405 033
0 460 405 034
0 460 405 043
4cyl l side 11m
0 460 414 079
0 460 414 101
0 460 414 106
0 460 414 118
0 460 414 131
0 460 414 137
0 460 414 171
0 460 414 175
0 460 414 186
0 460 414 190
0 460 414 192
could someone check all , i need to know where they are fitted, and if they have a 20mm drive shaft.
thanks.
