For Sale/Looking For => Parts for Sale/Wanted => Topic started by: RustyCaddy on April 07, 2013, 11:37:50 am
Thought i might rebuild a 1.5l motor but plans have changed.
Set of 0.50mm over, made in Germany Mahle pistons, w/ rings, pins and circlips. Some light oxidation in spots but should buff off. Asking $250.00 USD shipped in continental USA. Maybe last i'll ever see.
Also, 4 new precups to fit 1.5l (approx. 30.5mm diameter) but one is missing the ball bearing and another is miss labeled (?); might fit turbo head but made for NA (no triangles). Best offer.
Approx. 35,000 mile on rebuild 1.5l head, forwarned that it came off a high compression 1.5/1.6 hybrid that burned mostly biodiesel and veg oil, with oil return reducer, looks straight but i dont have machnists straight edge so selling as a core, no camshaft...best offer.
Pictures available on request.
ttt
ttt
ttt
btt
ttt
if it has an oil return reducer INSTALLED IN THE HEAD, then it is a 1.6 head that was used on a 1.5D engine..
or do you mean that the oil return reducer for the block is included with the head?
the 1.5 head has a very small oil return passage already.. the 1.6 head has the bigger oil (would need reducers installed if not being used on proper block) return passages.
The head has the small oil return. The reducer came from the VWparts forums sponsor.
