General Information => Troubleshooting => Topic started by: VW on March 04, 2013, 08:11:06 am
I have been looking through the forum for a similar issue to mine but did not find what I would like to know. So if someone does know of a link that could help I would be much appreciated.
I am sure this is a common but my 86 N/A Diesel Golf's fuel gauge works sporadically. Going from one side to the other but seems to only do this at like 3/4 of a tank?? If I fill the tank it shows full and stays there but as I use fuel it starts to act weird and starts to float all over the place. If I go around a corner it drifts over to the full side but then back to the empty. I am going to assume the sending unit is bad?? If that is the case is there a simple fix or do I need to replace it?? Does anyone know of a place that sells a quality new one? Thanks, VW
I hate to send people over to the vortex.. but when it is not a diesel specific question the mk2 forum over there gets TONS of traffic, and you will get an answer faster.
That being said, I dunno lol
If your sending unit is worn they can get bad spots at certain parts. That will cause pretty much exactly what you are describing.
Sent from my HTC One X using Tapatalk 2
Thanks, I wasn't sure where on here to post the question and decided this was the only choice. I am not registered with vortex but I guess I could? I appreciate the help. If I get an answer over there I will try to post it here just in case it could help someone in the future.
Thanks, again.
VW
I'll second the sending unit being bad.
