Engine Specific Info and Questions => IDI Engine => Topic started by: 92Ecodiesel on March 03, 2006, 08:39:38 am
Title: electric fans
Post by: 92Ecodiesel on March 03, 2006, 08:39:38 am
Hello, I am curious about the electric fan set up I got off the 92 eco diesel in the bone yard. I just picked up the fan set up to put on the turbodiesel engine I pulled from that car about 2 months ago. I notice there are 2 fans but only 1 of those fans has a motor. I am curious how the second fan works, does it just freely spin while driving down the road? I looked in the bently manual but it did not show the duel fan set up. Thanks for the info.
Doug
Post by: zyewdall on March 03, 2006, 09:31:47 am
Are you sure it's not just a fan with the motor built into the hub of the fan, instead of the giant motor sticking out like the stock VW fans?  I replaced mine with a subaru fan which has the hub motor, and got an extra 4 inches of clearance behind it.
All of the aftermarket electric fans are also hub motors.
Post by: BlackTieTD on March 03, 2006, 09:46:07 am
not belt-driven off the other motor is it? never seen that setup myself..
Title: Electric Fans
Post by: Fisher on March 03, 2006, 10:06:55 am
It's belt driven off of the other motorized fan.  The belt runs inside shroud.
Title: Re: Electric Fans
Post by: zyewdall on March 03, 2006, 01:54:49 pm
Quote from: "Fisher"
Wouldn't that be fairly obvious just looking at it?
Post by: Black Smokin' Diesel on March 04, 2006, 01:42:43 am
Quote from: "zyewdall"
Yes, unless the belt is missing. Stock fan motor is HUGE!!! I got two hub type 10" electric fans on my rad. There's much more space now but I have to relay them to make the two speed system work properly.
Post by: chrissev on March 04, 2006, 06:40:41 am
interesting.  never seen that set up.  is it for air conditioned cars?
Post by: QuickTD on March 04, 2006, 07:00:06 am
My A3 jetta has the belt driven fan setup, and AC.
Post by: stewardc on March 04, 2006, 07:37:02 am
My 91 Turbodiesel Jetta GL (no AC) in Canada , had that setup. The belt looks like a heavy duty O-ring.
