General Information => Troubleshooting => Topic started by: bbob203 on February 13, 2013, 08:33:15 pm
Title: A few wiring bugs
Post by: bbob203 on February 13, 2013, 08:33:15 pm
#1 Glow plug relay is ticking intermittently thought it had a pattern of when it would occur but now no idea. Only time it definitely does it is on an immediate restart after a long haul. Just on its way out? I dropped down the fuse box and nothing looked out of the ordinary in that department.
#2 I discovered a pretty toasty bown wire on terminal f connector some kind of ground? Any idea where it goes?
http://www.a2resource.com/electrical/CE2.html
Title: Re: A few wiring bugs
Post by: 8v-of-fury on February 13, 2013, 08:42:55 pm
Do you know the age of the relay? Remove it and test it.
There should be two brown wires in the F connector and they are both to the main fuse box grounds internally of the fusebox  which should go directly to the battery negative.
Post by: bbob203 on February 14, 2013, 04:21:01 am
Could be stock relay.. Only 1 brown wire on me battery.
Post by: TylerDurden on February 14, 2013, 06:55:46 am
The way I read the Bentley, the brown wires on bus #31 go to Chassis-ground.
Something drew heavy current through there... who knows when... any known short  (GP relay, Headlights, Cig lighter, Fresh air fan)?
Post by: bbob203 on February 14, 2013, 07:04:28 am
That wire was at one point poorly connected to the negative battery terminal it has since been fixed the whole casing on it looks like a kraft single in the microwave though bubly melty and crispy.
Post by: TylerDurden on February 14, 2013, 07:21:42 am
I'd be looking for other wires with similar issues, that current came from somewhere.
Post by: bbob203 on February 14, 2013, 08:38:17 am
I think it was from prolonged cranking when I was having injection pump issues.
new relay is in so hopefully that will cure my tick tick tick
Post by: bbob203 on February 14, 2013, 03:26:48 pm
glow plug relay still clicking after new installed ??? ???
Post by: 8v-of-fury on February 14, 2013, 03:35:11 pm
Give up on stock system. Install standalone glow plug system and be better off in life. ;)
Glows will get higher voltage and amperage, if it fails its right there in the open to diagnose, parts are all cheaper than one glow relay lol.
