General Information => General => Topic started by: shwak23 on October 29, 2012, 10:46:40 pm
Title: Has anyone seen this mess?
Post by: shwak23 on October 29, 2012, 10:46:40 pm
http://www.youtube.com/watch?v=ha6JwTY7RJY&feature=related
Pretty unusual....
Title: Re: Has anyone seen this mess?
Post by: 745 turbogreasel on October 30, 2012, 02:10:07 am
Same mess, more plumbing ;D
http://www.youtube.com/embed/j95usDKdhbA
Post by: libbydiesel on October 30, 2012, 07:28:47 am
I don't see two pumps on the volvo.
Post by: R.O.R-2.0 on October 30, 2012, 11:41:42 am
2 pumps, HOW THE F?!
and WHAT THE F?
double 2 cylinder pumps?
Post by: 745 turbogreasel on October 30, 2012, 12:19:39 pm
Its chain drive  below the stock one...
You can see the injector lines are T'ed in the vid, but here's a  pic.
http://www.garaget.org/?car=165910&image=1572144
Double stock pumps, no breakey  drive shaft at high RPM, well not the pump drive one anyway.
Post by: R.O.R-2.0 on October 30, 2012, 12:26:35 pm
holy shizzz...
you in theory have 2x fueling with 2 pumps, at the same RPMs, right?
wouldnt it be pretty important to have both pumps tuned IDENTICAL?!
Post by: rallydiesel on October 30, 2012, 12:40:58 pm
That's nuts. I've never seen anything like that with a VE pump. Anybody know where we could find more info on that one?
Post by: smutts on October 30, 2012, 03:00:47 pm
All that smoke shouts that it doesn't burn too well. Drilling and tapping an extra injector into each of those combustion chambers must have been bit of a chore. What is the horsepower limit of a single VE pump? 25kw per pot? x4 pots, x1.34102209 for horsepower, gives 134 horses. Okay I see why they might try this. Heath Robinson and Rube Goldberg would be proud. ;D
Post by: 745 turbogreasel on October 30, 2012, 03:04:10 pm
I don't think the timing  really does have to be spot-on, plenty of OEMs  use split shot injection.
There is no extra injector, just a T in the delivery pipe, and  delivery valves keep anything from  going the wrong way.
It also lets you get a ton of fuel without a big heavy  plunger that doesn't like High  RPM,  and a nice gentle camplate that won't skip as easy.
Makes sense, but seems like a lot of work  to get right.
Added bonus, limp home if a pump fails.
Post by: bbob203 on October 30, 2012, 05:22:11 pm
That was as much exhaust as everyone on the forum makes in one year.
Post by: R.O.R-2.0 on October 30, 2012, 05:26:24 pm
nah, diesels make LOTS of exhaust..
that D24 was barely running.. i wasnt impressed.
Post by: 745 turbogreasel on October 30, 2012, 06:23:49 pm
If my Swedish translator is right, it makes over 350HP.  Maybe not too surprising it's a bit cold blooded?.
Post by: libbydiesel on October 30, 2012, 06:26:53 pm
The VW one had two sets of injectors.
Post by: 745 turbogreasel on October 30, 2012, 07:12:38 pm
So it does, must be a long tunnel to the combustion chamber.
Here's a twin pump 6.5 setup https://www.youtube.com/watch?v=FwFWNReCmck
Post by: MJF on October 30, 2012, 09:40:42 pm
That Passat has 1,9 TDI, also 4wd :)
http://www.youtube.com/watch?v=kIESmuPaFsA&feature=related
