General Information => General => Topic started by: R.O.R-2.0 on September 28, 2012, 03:32:11 pm
Title: CHECK THIS OUT! G-Lader/Ancient GDI!!!
Post by: R.O.R-2.0 on September 28, 2012, 03:32:11 pm
check out this pic that i found on my facebook this morning..
i about pooped when i found it!!
(http://i702.photobucket.com/albums/ww28/Dubsmoke/A2AA18E5-4F39-4FF0-A2E0-C64B3BAD1B18-5604-00000571A7FE51DC.jpg)
appears to have a Bosch pump, and a G-Lader buried down under the injection pump..
Title: Re: CHECK THIS OUT! G-Lader/Ancient GDI!!!
Post by: CRSMP5 on September 28, 2012, 09:27:35 pm
mk2/mk3 mount..... intermediate shaft.... wonder vintage of pic..
Post by: RabbitJockey on September 29, 2012, 06:09:42 am
Look at the delivery valves on that pump, see how they come out on an angle?  Looks like a stanadyne pump,  very interesting, I'm not really into superchargers tho, and I'm not really sold on the whole misconception that superchargers give you boost faster.  I like the freespooling nature of a turbo where when u are going up a hill just accelerating in general all you have to do is give it more throttle and ucan get boost.  Unless ur already at a higher rpm you need to downshift with a supercharger.  The only time a supercharged really us an advantage is say you are just driving along and decide to suddenly down shift and take off.  Not that superchargers aren't cool, my brother has a supercharged slc and that thing flys
Post by: libbydiesel on September 29, 2012, 09:48:46 am
With my mechanical VNT15 on my 1.9 mTDI I can have 8 or 10 psi when I let out the clutch in first gear.
Post by: theman53 on September 29, 2012, 11:41:25 am
There is a ton going on in that pic. One of the things I am looking at is the alt driven on the back of the engine. And basically non of the pulleys on the front being correct to stuff we see. I wonder what engine it is?
Post by: rallydiesel on September 29, 2012, 01:30:29 pm
Almost looks like a photoshop to me. The oil pan is at a weird angle. Some of the brackets and location of tubes, etc. doesn't make any sense as far as continuity.
Post by: GTiTDi on September 30, 2012, 07:08:58 am
It is actually a direct-injection spark ignition engine.....It is throttle like a diesel by increasing fuel delivery rate/volume, there is NO THROTTLE PLATE!!! http://g-lader.info/fahrzeuge_studien_irvw4futura.htm (http://g-lader.info/fahrzeuge_studien_irvw4futura.htm)
Post by: mystery3 on September 30, 2012, 10:57:33 pm
That thing is COOL! I always like looking at old concept cars.
Post by: R.O.R-2.0 on October 01, 2012, 12:12:06 pm
late 80s..
the car they used this in, was produced in 89..
was put into the IRVW4..
Post by: R.O.R-2.0 on October 01, 2012, 12:14:50 pm
this engine is 100% REAL...
the car it came in, was also 100% REAL..
and it DOES LOOK JUST LIKE the stanadyne pump i just put on an olds 5.7D..
and i really wonder how crack-prone that head was, with a spark bolt, and a fuel infector in each cylinder?!
Post by: gldgti on October 04, 2012, 05:40:16 pm
probably no worse than the IDI heads... the void from the prechamber is significant when you include the glow plug holes and hte injector port too.
