General Information => Troubleshooting => Topic started by: mtnbob on August 14, 2012, 03:55:08 pm
Title: Fan not working--Suggestions on where to start?
Post by: mtnbob on August 14, 2012, 03:55:08 pm
My fan is not coming on. I think it started before I replaced the engine. Any suggestions on how to diagnose it, or where to start looking?
Title: Re: Fan not working--Suggestions on where to start?
Post by: bbob203 on August 14, 2012, 06:17:01 pm
bust out the bentley there is good instructions on diagnosing fan problems.
Post by: mtnbob on August 14, 2012, 07:29:33 pm
hmmmm i'll look again
ty
Any luck on the metal pipe for the td cooling
Post by: theman53 on August 14, 2012, 07:35:06 pm
Easiest would be to check the wiring/connectors first.
Post by: bbob203 on August 14, 2012, 07:42:10 pm
ty
Im gonna go to jy tomorrow.
Post by: Dakotakid on August 14, 2012, 08:36:11 pm
Start at zee fuse, mon. 30 amp. Green.
Post by: CRSMP5 on August 14, 2012, 08:56:50 pm
my 1st step.... hook up battery..
2nd unplug thermo switch on rad.. cross 2 wires with homemade jumper.. no run.. keep jumper in... this to be rehooked last.. y.. you will see..
3rd check fuse... if blown replace... fan on?? jumper will turn fan on... so this way as you check each part.. it will tell when fixed..
relay also on needs checked... but my 1st 3 steps above
Post by: mtnbob on August 15, 2012, 03:30:42 am
ty
Post by: JessaBug on August 15, 2012, 06:46:23 am
Wouldn't be surprised if it was the thermo switch. We put in a new one 2 years before our rebuild. All worked great. Put the engine all back in, switch was dead. We tried everything but that stupid switch because we thought there was no way it could be dead  >:(
Post by: Dakotakid on August 15, 2012, 04:12:50 pm
Well, ALL the above is good advice.
But, as some other obvious problems have arisen in the last couple days......are you sure the engine is warm enough to activate the fan cycle? Are BOTH radiator hoses getting good and hot?
Do you have a formerly consistent temp guage in this car?
Post by: mtnbob on August 16, 2012, 12:43:55 am
Of course, I have the a/c model, so the wiring is 10x more complicated. Yes the temp gauge has always worked well, and the engine is warm enough to kick the fan on.
