General Information => Troubleshooting => Topic started by: mtnbob on August 12, 2012, 04:36:41 pm
Title: Clutch has no resistance
Post by: mtnbob on August 12, 2012, 04:36:41 pm
I hooked up the clutch, shifter linkage, and cv joints. When I went to start the car, I realized that I had almost no resistance from the clutch pedal. After you put on a new clutch, is it very easy to push, or did I screw something else up? The arm on the transmission moves pretty easily, much easier than before. Any ideas what I might have missed?
TY
Title: Re: Clutch has no resistance
Post by: mtnbob on August 12, 2012, 05:57:55 pm
Any ideas?
Post by: theman53 on August 12, 2012, 06:22:53 pm
did you put the pushrod in?
Post by: mtnbob on August 12, 2012, 06:30:40 pm
I hope so. Will check after dinner :o
Post by: mtnbob on August 12, 2012, 07:52:44 pm
Maybe a dumb question, but is it possible for the clutch to be stuck in some way? maybe when I put it together, that it isn't pushing back on the pushrod?
Post by: mtnbob on August 12, 2012, 08:07:50 pm
I took off the end cap to find that the throwout bearing and pushrod were installed correctly ??? So this probably means deeper problems. There is no pushback from the throwout bearing and pushrod at all  :'(
When I put on the release plate, was it supposed to fit into the indentions of the clutch pressure plate?
Post by: R.O.R-2.0 on August 12, 2012, 08:15:31 pm
the clutch push plate only goes on the right way.. you can not assemble that plate wrong..
your push rod might be the wrong length..
or else your clutch throw out finger is broken.. they LOVE to break..
Post by: 8v-of-fury on August 12, 2012, 08:20:38 pm
Your having all sorts of issues aren't ya? ;) Gotta slow down before you set something on fire and loose it all! lol
I have a suggestion to make, Google search ETKA 2007 and find a torrent to download.. One of your sons will be able to help out no problem, it helps SO much. :)
So looking at this blow-apart from my ETKA;) it shows us how everything should go together. Not really possible to screw up the clutch and have it even go together to begin with. Sure you could have put the pushrod in backwards, but it wouldnt hinder clutch operation. Does the pedal go to the floor? Did you start the car with it in gear and the clutch to the floor? Or are you a neutral starter no clutch like myself lol? Did  the clutch work at all?
(http://i299.photobucket.com/albums/mm307/J_holubek/Random/Untitled-1.png)
Post by: Dakotakid on August 12, 2012, 08:27:38 pm
How about item #14 on the above diagram?
Did you inspect it prior to assemble to ensure the center "button" was in good shape and not totally worn out or even already "holed?"
Getting holed always causes problems...........
Post by: mtnbob on August 12, 2012, 08:30:03 pm
Ok first of all I'm not that old(47) that I'm not well acquainted with torrent files. ;D  I have two Bentley books I have been following. This is my first try at something this ambitious!!
I started the car the first time without the cv axles attached to see if I could start the engine first.
I then attached the cv axles and put the car in neutral and started it again.
I pushed on the clutch pedal and instantly noticed almost no resistance.
The pushrod was from my transmission from the 1.6 N/A. Would a different engine(1.6 TD) use a different pushrod length??  The arm seems to be working properly, it just seems like the release bearing is in there too far and I can only get it out with a magnet. Should I be able to push on the release bearing with something to tell if it is engaging at all, or is it take too much force to do that?
Post by: 8v-of-fury on August 12, 2012, 08:30:15 pm
Good point, I figured he did a new clutch it was probably replaced.
Post by: mtnbob on August 12, 2012, 08:31:35 pm
The release plate was fine
Post by: 8v-of-fury on August 12, 2012, 08:32:28 pm
LOL I AM SORRY! I only assumed.. well that you were old.. lol my bad
There is no way you will push the realease bearing in by hand, ever. Also I bet there isn't a man among us VW guys who could lift up on the clutch arm enough to actuate the clutch at all.  It is a strong spring on that pressure plate, the pedal shouldn't be hard, after all it was only a stock clutch right? Should be super easy.
Post by: mtnbob on August 12, 2012, 08:40:10 pm
So what is up with pushrod length? The Bentley mentioned nothing that I saw about different lengths of rods. I'm going to take a closer look at the arm. But it did work perfectly when I used it last a month ago, so I am back to examine again!
Post by: 8v-of-fury on August 12, 2012, 08:40:52 pm
4spd is one length, 5spd is another. Only two lengths.
Post by: R.O.R-2.0 on August 12, 2012, 08:46:49 pm
yup.. if your old trans was a 4 spd, then the push rod will NEVER work in a 5 spd..
Post by: Dakotakid on August 12, 2012, 08:47:09 pm
Did you use the little plastic clutch centering tool?
Clutch plate installed like in the diagram with the little "outie belly button" oriented correct?
While we are at it (a little sidetracking here to attempt to avoid any other problems.....like one other fellow who frequents this forum had last year when he put an engine together and then roached his crank end.... ::)) did you use some blue locktite on those pressure plate /crankshaft bolts and torque them to (is it) 72 ft. lbs.?
How about the little 9 mm bolts which only go to 15 lbs.? Just checking......hate to see this crank have to come out and go to machine shop like the last guy!
Post by: theman53 on August 12, 2012, 08:48:41 pm
I always email brokevw in these situations. He always has asked me if the arm on the trans can be lifted past the 9:00 position. If it can then something isn't right. Another thing he has pointed out is the finger the guys have said already. It doesn't have to "look" bad. If it is bad it won't push on the plate and it will seem as the clutch won't work. You should have pressure though if the PP is pushing against the plate and the plate on the pushrod. Check out piece number 20 in the diagram above and see if it has a crack...or email Brokevw for things to check.
Post by: mtnbob on August 12, 2012, 08:52:04 pm
Yes I used new bolts with locktite(they came that way) and torqued them correctly. I believe i put the plate in the right way. The arm does not go past 9 O'clock. I will go out and look at the arm again.
Post by: mtnbob on August 12, 2012, 11:42:26 pm
Clutch is fixed. It was completely an novice mistake from me!!!!!!  I reread the Bentley and read everything everyone said and realized that the arm was supposed to be within about a 1/2" from engaging when properly adjusted. I had to open the adjustment up quite a bit to get there. When I did, all was fine.  :o  Kinda embarrassing, but I'm learning as I go.  I actually drove the car a mile down the road tonight. I still have some small leaks to track down,and need to do one more cycle of tightening on the headbolts, and numerous other small things, but it is running!!!!!!!!!!!!!!!!!
Ty for everyone's patience!!!!! I know I've been a real pain, but hopefully I've learned alot from this ;D
