Engine Specific Info and Questions => IDI Engine => Topic started by: camboscams on July 28, 2012, 11:19:43 am
Title: Quick ac bracket question
Post by: camboscams on July 28, 2012, 11:19:43 am
Can the ac bracket that bolts to the engine be removed without removing the injection pump and bracket? Its a mk1 1.6l btw
Title: Re: Quick ac bracket question
Post by: justiz00 on July 28, 2012, 11:24:49 am
I just went thru this on my 1.6na. and sadly I could not do it. If you have the motor out of the car then you should be able to get upper left one but the upper right is hidden behind the pump.
Post by: bbob203 on July 28, 2012, 01:39:39 pm
You might be able to do it with 1/4 extensions and a uni joint socket. but what he said. :-\
Post by: TylerDurden on July 30, 2012, 08:30:06 am
Can sometimes be done with an "S" wrench. Not easy if the bracket has been on for a decade.
Post by: camboscams on July 30, 2012, 12:34:45 pm
Gotcha hopefully i will be that lucky. time will tell
Post by: CarlosA on July 31, 2012, 06:10:25 pm
I actually *had* to do that on an engine I was working on last week. The lower bolt for the IP had broken loose of its bracket and was just spinning - couldnt get in there to hold it without removing that bracket, was a nightmare for sure, but this wrench helped:
(http://i.ebayimg.com/00/s/MjU4WDQ2MQ==/$(KGrHqF,!nsE8U9l-m2+BPOu5!Mzng~~60_35.JPG)
I usually use it for adjusting the IP.
Post by: theman53 on July 31, 2012, 07:03:18 pm
I cannot remember which bolt, but I have a set of flex head gearwrench and it will almost go anywhere. The only hang ups are if the head of the bolt or nut is recessed or blocked in that way. IIRC I can get all the hard to get IP bolts with it...and it is the handiest 13mm wrench I own for other things.
