Engine Specific Info and Questions => IDI Engine => Topic started by: kevinm on April 23, 2012, 09:15:06 pm
Title: question regarding leaky turbo line
Post by: kevinm on April 23, 2012, 09:15:06 pm
<a href="http://s276.photobucket.com/albums/kk17/kmahon01/?action=view&amp;current=turbofitting-1.jpg" target="_blank"><img src="http://i276.photobucket.com/albums/kk17/kmahon01/turbofitting-1.jpg" border="0" alt="Photobucket"></a>
Im wondering if the end part is supposed to spin freely, not the part im holding but the part above my fingers.. I notice the end that hooks up to the turbo does not spin and the one on the oil filter manifold does?  and should i try to hit the fitting with some scotch brite to help with the seal?  Just trying to troubleshoot a leak.  Thanks.
Title: Re: question regarding leaky turbo line
Post by: kevinm on April 23, 2012, 09:16:09 pm
(http://i276.photobucket.com/albums/kk17/kmahon01/turbofitting-1.jpg)
Post by: bajacalal on April 23, 2012, 09:28:19 pm
It's a ferrule. It's a separate piece from the tubing and then when you tighten it down it squeezes it on there so it seals by compression when it's compressed. As long as it's not too squashed or too loose it's probably fine.
Post by: 745 turbogreasel on April 24, 2012, 01:05:12 am
Yes, get it very clean, and tighten it just enough it doesn't leak.
If the other  fitting can be counterheld while tightening the pictured part to it, do so.
