Engine Specific Info and Questions => IDI Engine => Topic started by: xxkoadyxx on April 19, 2012, 02:40:05 pm
Title: oil in coolent..
Post by: xxkoadyxx on April 19, 2012, 02:40:05 pm
Sooo I drove home one day and there was oil coming out of the overflow bottle and spilling everywhere..sooo I replaced the head gasket with a new one, cleaned the matting surfaces annd put new bolts in. I also replaced the timming belt and tensioner.
Iv flushed the coolent system out for over and hour with the car running..and oil still keeps coimg out. I drove to work and on the way back, it was blowing oil out of the bottle again..I'm lost..this is my daily soo I need it fixed. Its a 93 1.9td 400kms.
Iv asked around and had a couple people say oil cooler? What do you guys think?
Title: Re: oil in coolent..
Post by: gnavs on April 19, 2012, 03:11:00 pm
I'd look there too.  Anywhere the oil and coolant are in close proximity to each other, but that would be the first place I'd check.
Post by: R.O.R-2.0 on April 19, 2012, 04:15:23 pm
i would have replaced the oil cooler before the head gasket..
the coolers are known to fail, the head gaskets are NOT.
Post by: dieselweasel on April 19, 2012, 04:22:28 pm
[/quote]
Me too, although when I had oil in the coolant, I replaced the oil cooler first--head gasket was at fault.
Post by: R.O.R-2.0 on April 19, 2012, 04:30:33 pm
[/quote]
sometimes that IS the case, but more often than not, its the oil cooler..
i would always suspect cooler first, unless you did something to the car recently that would warrant the head gasket being compromised
(over heater, turned up the boost, whatever)
Post by: CrazyAndy on April 19, 2012, 04:33:39 pm
If you did that good a job of cleaning your head gasket surfaces and made sure the y were perfectly flat, then as everyone says definitely do the oil cooler.  As R.O.R. said, they are known to fail; I in fact just did one on a 03 Passat at work today.  Definitely not the first.  So go ahead and replace that, and don't forget a new oil cooler gasket when you get it.  ;)
Post by: xxkoadyxx on April 19, 2012, 05:00:15 pm
Oh, I figured it was the head gasket. I will be buying a used oil cooler and trying that. See if that works. If soo, ill save up for a new one..just kinda broke from doing head gasket and belt -_-.. Also guys anything I should look for when doing the cooler? Ill need a new oil filter again? I just but a new bosch one in there 2 days ago with new oil.soo I'm gonna have to replace them again?
Post by: R.O.R-2.0 on April 19, 2012, 05:01:52 pm
why would you have to replace your oil and filter? as long as you dont contaminate the filter, i see no reason to replace it..
all you need, when replacing the cooler, is a new seal for the cooler..
i use oil filter gaskets as oil cooler seals, FWIW..
Post by: CrazyAndy on April 19, 2012, 05:39:43 pm
What he sez; don't worry about the oil filter.  The oil system is way more pressurized than the cooling system, so oil only goes into the coolant and not the other way around.  And taking off the cooler will not in any way get coolant in the oil.  Just make sure the used one you get is a known good one, from a reputable source.
Post by: billybobf on April 19, 2012, 05:49:34 pm
is there a way to pull off his old one and maybe put water pressure to the coolant lines to test it? see if water comes out the oil ports? (off the engine of course)
also, I would like to mention. yes the oil pressure is HIGHER then the coolant pressure, UNTIL YOU SHUT OFF YOUR ENGINE. at this point, hot spots on the engine normally increase pressure to as high as the cap will hold, and at the same time the oil pressure has dropped off, normally pretty rapidly too. so for the first 2-5 minutes after the engine has shut off, technically the coolant pressure is higher then the oil pressure
Post by: xxkoadyxx on April 20, 2012, 03:56:56 am
I have to agree with this, because when the car is running, the coolent/oil is slowly overdlowing the bottle, when I shut the car off, it sucks it back in.. Also I put 15-w40 in it cause I didn't wanna spend a lot on. Oil. Good thing I didn't cause I might have to change it..when I wipe the oil off, it wipes off into the white rag kinda gray..on the dip stick it shows its full..but not much oil seems to come off
Post by: theman53 on April 20, 2012, 04:23:08 am
You should be able to run tap water through the coolant sides of the oil cooler. Most houses kick the pump on at 40psi, usually above that with the pump running, and that should do it as the vw system will only show about 1/4 of that.
Post by: xxkoadyxx on April 20, 2012, 11:21:59 am
Soo I had the running for an hour again today, checked oil before "1/2" on the grid. Flushing and flushing and flushing. I think my rad is clogged cause water won't flow through it... Also took forever for the car to get up to temp. Got annoyed with it so shut the car off..now only a little bit of oil on the dip stick..sooo its going somewhere.I'm pretty sure into the coolent cause when I took bottom hose , oil came out. I'm gettinf pretty fit up with it..
Post by: bajacalal on April 20, 2012, 03:07:01 pm
Are you flushing it with regular water or with a detergent added?
And, if you still have a faulty oil-cooler (or head gasket) you are just going to be adding more oil to the system. Until you actually solve the problem there is no point in flushing it.
Post by: xxkoadyxx on April 20, 2012, 07:14:24 pm
I'm using just water, cause idk what is safe to use. Also iv just done the head gasket and all tq'ed down.. The only thing I can see, is the oil cooler.
Post by: 8v-of-fury on April 20, 2012, 09:51:11 pm
Why are you flushing when you have not taken the problem out of the equation? lol. You still have oil going in to the coolant, you need to stop that oil leak before you flush.. I take it the hour you were flushing with oily water coming out was going down your driveway and in to the sewer as well eh ;).
Post by: ORCoaster on April 21, 2012, 08:56:52 am
So that is why fish are oily?
Post by: R.O.R-2.0 on April 21, 2012, 12:46:03 pm
put some DAWN dish soap in with your water, it will wash the soap out, if it doesnt, then you need an oil cooler..
i would just replace it anyways.. ive seen them fail ALOT. like, at a fairly alarming rate..
just think of it, the coolant is in contact with it, and most people change their coolant about  once a life time, so it tends to get slightly acidic.. what happens when aluminum comes in contact with acid? it corrodes..
Post by: xxkoadyxx on April 21, 2012, 03:33:26 pm
Alright thanks! Do I need to drian the oil? Or can I take the oil filter right off and the cooler with oil still in the engine?  And yes, there's a friggin mess of oil all over the driveway :( also the rad seems clogged..cause when I pour water in it with bottome hose off, nothing comes out.. :/ soo I think that's why I keep blowing water out the expansion tank? Soo what's the best thing to clean that out? Take it out of the car and put and air compressor to it? ( Just the rad)
Post by: bajacalal on April 21, 2012, 06:23:59 pm
You might want to pull the radiator and fill it with a de-greaser type solution, let that soak a while then flush.
It could be too clogged though. I know radiator shops can take them apart and clean them out but it may not be worth it... you might need a new radiator.
Realize that if you add water to the top of the cooling system (the tank) and if the thermostat is closed, you have to pretty much fill the hole engine block to the top then it starts flowing into the radiator, which means you will need at least a gallon of water.
No, you don't need to drain the oil, you will just lose whatever oil is in the filter (maybe a quart or less) but if you think coolant has gone into the oil (if the oil like chocolate milk) then you need to change it ASAP. I would change it just to be sure, but only once you have fixed the oil/coolant mixing problem.
Post by: xxkoadyxx on April 22, 2012, 05:56:05 am
Ok thanks, I'm gonna take the rad out and try to flush it out, gonna try to get some degressor for work. But if that doesn't help, ill just get a new rad. And I'm sure I'm still getting oil into the coolent, I don't think any is going into the engine because I'm lossing oil not gaining it. And the oil in engine is black..but ill chang it anyways again after I figure out the problem. The water that comes out the over flow is chocolate milk..soo its still gettin oil.
