Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: Toby on April 09, 2012, 02:11:29 pm
I am going to look at a pile-o-turbos tomorrow, all purported to be TDI stuff. How do I identify the ones that I am interested in?
Other than the numbers which may be hard to read in a low light situation. He claims they are all ALH from '99-'03 and BEW from '04-'06, but I am not sure he knows what he is talking about. So which ones do I want for my (IDI) Low Bucks GTD? The VNTs should be pretty easy to identify, but are there any others worth picking up?
All those turbo's should be a variable vane turbo if they came on the diesels after 1999. I am pretty sure VW did not go back to a waste-gated turbo after the VNT debuted.. but I could be wrong.
your NOT wrong Jer...
VNT it is since 99
let me know if he has more than 1 VNT, and if you will want to part with any.
im looking for a VNT now, but if the deal falls thru that im looking at, i need to find one elsewhere..
would even settle for a couple GOOD cores to rebuild if you cone across any in that pile of turbos..
The clown has gone to ground again. As soon as I can get him to respond, I will go see them. What is a core worth?
About $50 - $100.
