For Sale/Looking For => Parts for Sale/Wanted => Topic started by: professor_fate on March 27, 2012, 06:19:37 pm
I'm looking for a decent Land Rover TDI injection pump. I'd be willing to pay for shipping across the pond if the pump is in good condition.
Check Ebay.uk
sadly any you buy you have to "assume" it as a core... install and cross fingers... :D
post links to any you think of buying.. ill peek at pics to mke sure its proper design..
rember you will need a mk4 style pully and hub for it... the vw tdi valves to fit the lines properly.. and have to build a rearm mount and mod the linkage to fit vs cable set up..
but its all cake stuff..
Here is a picture of the pump I'm considering. The man says it's been rebuilt and calibrated by a shop in the UK.
The motor that this LR pump is going on is from an 01 Beetle. Would the pump on it already have the proper pulley/hub and valves?
yep the nb would have the proper delevery valves and pully/hub set up.. you will still need to make the rear mount/throttle linkage but it pretty much bolts right onto that engine..
