Engine Specific Info and Questions => IDI Engine => Topic started by: dieseltim on February 10, 2006, 11:17:49 am
Ok, I have lots of pieces and some machining capabilites. So, I decided to take some of the parts and see what I can make from them. So, I am going to try to fit a 1.8ltr PG (corrada) block with a 1.9tdi head and a worked over 1.6td pump and injectors turbo and intercooled. The question I have is what size are the pistons in the newer 2 ltr tdi engines? I found that the 1.8 is already bored bigger with a shorter stroke, than a 1.9 tdi. So, now I need some pistons for a diesel that will fit in an 80mm bore and give me the compression I need to make this monster run. I know from reading here for some time that I am not the only one that is trying to put together something a bit different. I am hoping to get about 2 ltrs and around 140-150hp from a non-computer engine for my 91 2dr jetta, everyday driver.
Dieseltim :D
i'd really like to see a diesel made with an aba bottom end
you'd better use a tall block because the longer rods can handle more pressure.
the 2l 16v tdi have 81mm bore and 95.5mm stroke, exactly the same as the 1.9l diesels.
how do you want ro reach 2l? the bigger the bore will get, the more difficult it will be to reach a good compression ratio.
cr should be >=20:1 to get a smooth idle
cool idea, keep us posted :)
AAZ's used a 79.5mm bore.
my fault, i should have related my words to the stroke only :oops:
Not a problem, I just didn't want anyone to get confused :D
i think that an aba with a 1.9 idi head and diesel pistons would probably be one of the most beneficial franken engines (aside from a vr6 tdi :twisted:) anyways especially an obd I block since it has oil squirters
You are going to need custom rods, don't use a gasser block, the webbing internally isn't as strong, hence why big HP gasser guys use diesel blocks. Also the 1.6td pump is going to give enough fuel pressure to make much power with the tdi injectors.
$h!t€ :shock: :shock: :shock: :shock:
Good Luck...
Ok, can anyone tell me about the pistons from a touareg tdi. From what I have found this pistons are 80.97mm but, I am not sure if they use the same wrist pin size. Can anyone tell me where I can find 4 of them?
Thanks,
Dieseltim
also, the PG blocks (G60) were made alongside the diesel blocks on the same line, with the same tooling. there are actually a number of similarities but i read that article years ago...too long to quote anything. i'll try to dig it up. essentially they did it that way so the PG blocks would be as tough as diesel blocks and they could re-use existing tooling.
Yes,
Blacktie, I am using the PG block to start with. I have found that the v10 TDI pistons are just a bit larger 80.97mm, then the block is right now 80.00mm, so. If I could find 4 of them, then maybe I can put together a PG block with a 1.6 or a 1.9 crank and rods w/ a 1.9 td head and a worked over injection pump and oversized injectors (maybe from my old 2.3Peugo 505d). I think that would make it just over 2ltrs.
The PG has the same oilers and looks like everthing is the same as the 1.6td w/ just a larger bore. I am going to get the gauges out soon and check all the diam. and see if I can find anything other than the stroke and pistons that are different. I will post some pic in a few weeks. I am just trying to see if I can bolt together something from parts and get a bit more power without having to spend lots of $ for custom parts and machine work.
In the long run it is just for fun anyway.
Dieseltim :)
love it!
Yes,
Dieseltim :)
Problem with that is the v10 tdi pistons are completly differnt and wouldnt even work if you were doing a tdi enigine unless you could get the injector and valves in the right spots. :wink:
Ok, well that is why I was asking, I don't have one here to check specs of so until I can get info on specs of parts I am just looking. Like I said it is just for fun. So, if I come up with something that will work then great, if not then ok too. Any one have specs on the 2.0 tdi bore and stroke? Or maybe a set of pistons for a 2.0 tdi they don't need anymore.
Thanks, Tim
they won't work, too. the have e large omega-style hole in the middle to squish the air/diesel mixture. the CR would be ~17:1
if you have a g60 block then it has 81mm bore. i'm waiting for my flat 81mm pistons, that would give me 1.8l
if you want more try to get a set of 9A pistons with the corresponding crankshaft. CR can be adjusted up to 22:1 and that stuff should handle the expectable power
I would have to say that "custom" is about your only option. Maybey oversize 1.9TD pistons??
is that related to me? if so, the pistons are from a gasser :wink:
sorry no that was to Diesel Tim, as he was looking at using V10TDI piston's.
End Highjack :wink:
i think the only place you could find v10 tdi pistons would be the dealer :cry: but it would be interesting you would have to for sure make or get custom rods. Im sure it wouldnt be hard to find someone to custom make stuff for you. The only thing is when you start going full blown custom like you want to do it starts costing big dollars for something that might not be worth it. Just my two cents. I just think if you have a light car you can make it dam fast just using a 1.6 or a 1.9 worked over.
Jeff
its a cool idea but as soon as you need custom pistons/rods like jeff said, it sort of kills the whole "cheap project for fun" aspect. i'd like to see you make it work... know any machinists?? :)
Well, yes I can do some machine work but, if I can find some pistons that are 4th over (1mm over) for a TDI then maybe I can still do this without having to spend much time on the lathe or mill.
Dieseltim :)
