Engine Specific Info and Questions => IDI Engine => Topic started by: wdkingery on March 22, 2012, 05:04:02 pm
Title: providing oil to a turbo
Post by: wdkingery on March 22, 2012, 05:04:02 pm
I have the vnt, and I swore prothe had a td oil filter flange... But I cannot find it anywhere on his myriad of sites. Isn't there a spot on the head I can work from? Any other ideas?
Title: Re: providing oil to a turbo
Post by: R.O.R-2.0 on March 22, 2012, 05:13:22 pm
not enough volume from the head port..
modify a n/a filter flange!
Post by: rallydiesel on March 22, 2012, 05:18:38 pm
Couldn't you just use the n/a filter stand and use a "t" fitting for the pressure sensor? I'm assuming the n/a stand has an access hole directly above the filter?
Post by: R.O.R-2.0 on March 22, 2012, 05:21:15 pm
usually there is a secondary, plugged port on it also..
Post by: theman53 on March 22, 2012, 06:05:16 pm
I drilled and tapped my N/A flange to 1/4" NPT.
Post by: wdkingery on March 22, 2012, 06:11:13 pm
yes i reckon it might go this way. i'll attempt to figure it out.
thanks for the mount lucas!
Post by: 410 on March 22, 2012, 06:20:06 pm
The AHU TDI engine used the head for supplying oil to the turbo.  The oil line threads into the same port that the oil pressure sensor uses.  I bet it would work fine on the 1.6 also.
Post by: R.O.R-2.0 on March 22, 2012, 07:10:26 pm
AHU had a WAY DIFFERENT oiling system than the 1.6. chain driven high volume oil pump.
im going to stand by what i said.. i dont think the old 1.6 will supply enough volume to the head port..
Post by: theman53 on March 22, 2012, 07:12:57 pm
I don't think I would trust a head supply either, but I was thinking the AHU was the same as the AAZ block wise? I know the ALH has the chain pump, but did the AHU?
Like I said, I never saw much oil to the cam in the head, so it woud scare me to run it there. Also, IIRC the head is last to see the oil, so running it off the flange should be cleaner oil if nothing else.
Post by: 410 on March 22, 2012, 07:31:58 pm
ROR, you're thinking of the ALH.  AHU was an AAZ block with a crank sensor added.
5/16" OD steel tubing (brake line) works as oil supply line with the stock VNT turbo oil supply fitting/nut and part# 52215K507 from McMaster.  Drilling the filter flange to NPT and using an NPT to 5/16" compression fitting and a tubing bender would get it done.  Done forget to add at least one anti-vibration clamp to the line.  Also easy to make using sheet metal and a short piece of 5/16 ID hose.
Nicely said Libby.  Anything I build now I use #4 Stainless steel braided line.  My compound build uses one feed off the oil filter stand and the other turbo is fed from the back of the head.  I primed the engine before I fired it up and I got tons of oil flow from both lines.
Post by: R.O.R-2.0 on March 22, 2012, 07:36:58 pm
sorry.. my bad!
that kinda embarrasses me a little bit..
Post by: wdkingery on March 22, 2012, 07:46:18 pm
so this means i can use the head or no?
i'm not sure about the drill tap.
also, does the brake line bolt directly to the VNT?
Post by: fatmobile on March 22, 2012, 09:23:18 pm
 Yes, I used 5/16" brake line for my VNT 15.
 Drilled 1/8" NPT and got a compression fitting from Napa.
 The stock fitting on the VNT will accept 5/16" brake line in it's compression fitting.
Post by: VW Smokr on March 22, 2012, 11:50:55 pm
... so this means i can use the head or no?...
Especially if you're using a stock pump on a factory '85 Golf/Jetta 1.6, I'd agree with theman53, inasmuch as the cam and valvetrain need all the oil pressure & volume that finds its way up there to the head. Sometimes even that's not enough.:(
The filter flange is a much better source from which to lube the turbo on a 1.5 or 1.6. Going to a higher volume pump might be of benefit also.
J.R.
SoCal
Post by: fatmobile on March 23, 2012, 07:15:54 am
I forgot to mention;
 the Rabbit oil filter flanges don't work with the oil cooler sandwich plate.
 The seal surface isn't wide enough.
 If you are going to drill/tap a filter flange, use a later one with the wider seal surface so you can put an air-to-oil cooler on it.
Post by: wdkingery on March 23, 2012, 02:10:53 pm
Found some have the spot already tapped, with a plug in them. But they are a booger to get off
Post by: R.O.R-2.0 on March 23, 2012, 02:17:53 pm
most are drilled/plugged..
but they are threaded in metric M10x1.0, witch is VERY CLOSE to 1/8" npt, but not quite the same.
Post by: 410 on March 23, 2012, 07:24:04 pm
Very true.  I'm guilty of cranking in a 1/8" pipe thread into one of these holes.  No leaks and never had a problem.  I don't recommend it though.
Post by: wdkingery on March 23, 2012, 07:59:27 pm
I'll be doing exactly that :-)
Post by: camboscams on March 24, 2012, 01:33:30 pm
For whats its worth, i have been supplying my vnt and the turbo before that with oil from the cylinder head location. I also primed my engine prior to swapping on the vnt and had quite a bit of flow.
