General Information => Troubleshooting => Topic started by: Vohaul on February 04, 2012, 08:05:58 pm
Title: ARGH...overheating...
Post by: Vohaul on February 04, 2012, 08:05:58 pm
Ok, my 93 aaz td is in my wife hands an hour away..and she says its overheating...temp light on dash is flashing...and up to 110 on the guage.....
it ran perfect yesterday....no problems...anyway she topped up the resovoir and says its leaking out the side nearest the fender....and it starts heating up again...
whats a common problem for these cars that can happen just like that with no warning..... ???
sigh, why the car has every issue in the book when my wife has it, but works perfectly when i use it is beyond me...... ???
Title: Re: ARGH...overheating...
Post by: Vohaul on February 04, 2012, 08:27:01 pm
i think my car seriousky hates my wife.....
shes trying to start it...all she gets is the stock alarm sound.....grr...then finally it starts and the battery light stays on....did i mention the oil light is flashing.....
sigh....i really have no idea what is going on with it.....
i had her buy some premix antifreeze and oil.....topped them both up...honestly its the only thing i can think of.....
Post by: Baron VonZeppelin on February 04, 2012, 08:47:52 pm
It sort of sounds like she is killing your car.
On average, women don't stop - or call - until its too late.
Wonder if she could be more specific for you about where the coolant is leaking/escaping ? Is it a cracked reservoir/globe ?
Maybe she should park and wait for you or get a motel room ?
Post by: mystery3 on February 04, 2012, 09:01:25 pm
Call AAA or Canadian equivalent? I imagine bad things have happened already.
Post by: CRSMP5 on February 04, 2012, 09:58:44 pm
belt snapped.. not turning waterpump and got hot enough to fry things and oil light on due to that..
Post by: Vohaul on February 05, 2012, 12:08:13 am
Ya right on the moneyI went and picked her up..... First thing I saw was no belt... Sigh
She said it was idling fine and the temp gauge was ok.... Then the lights turned off and radio slowly died ... Then the engine shut off....did she blow the motor? I'm going tomorrow to get it and put a new belt in
Post by: CRSMP5 on February 05, 2012, 07:20:43 am
if she drove it long enough for the batt to go dead due to no belt.. i would not be hopefull... think abt it.. how long can a diesel run when the alt fails.. i know i can get a good week if i do not run lights so on..
so i suggest be prepaired to tow it..
what sad... no belt = alt light on... she killed it on purpose..
Post by: Vohaul on February 05, 2012, 09:18:28 am
Well she did have all the lights and radio on
Putting the new belt on now does anyone have a diagram for the belt path handy?
Post by: smutts on February 05, 2012, 09:46:46 am
When my belt snapped, it was -15C. Less than half a mile after the charge light came on (ie. belt snapped and the waterpump had stopped) the coolant light came on as ALL the coolant blew out. The battery will last a LOT longer than half a mile, so I wouldn't get your hopes up much.
I nearly died of hypothermia waiting for the fixers to turn up. :(
Post by: R.O.R-2.0 on February 05, 2012, 10:58:41 am
prolly the plastic flange on the side of the head leaking like a sieve..
or the plastic coolant bubble..
or a heater hose..
or anything really..
hopefully she DIDNT burn it down.. women usually DONT stop until the car forces them to (seized engine)
Post by: CRSMP5 on February 05, 2012, 12:57:08 pm
that is how i know abt the ac kill thermo switch in the neck off the head... a guy who's wife did this before had the one shop i work at use that switch to run the fuel pump wiire thru it.. so when it got too hot the engine would shut off automatically..
very simple idea.. kinda late now though..
Post by: JessaBug on February 05, 2012, 12:57:53 pm
 Not all women are like that  :-\
My husband and mechanic were quite proud that when I busted the oil pan on my NB, I stopped right away and turned off the car. No damage whatsoever. A lot of people (guys too!) wait until the oil pressure light comes on and by then its too late.
Post by: 8v-of-fury on February 05, 2012, 03:01:49 pm
WOW SEXIST MUCH!?!?!?
Agreeing with Jess here, its not women that are the problem.. it is ignorant people who do not care to think things through. Male or Female.
In my time, i have met PLENTY of people who drove their cars to the graveyard because of something so small and easliy overlooked.
I drive an 84 1.6 n/a so there is always something that needs my attention under the hood lol, i have the hood open at least once a day if not more. And every time I check all four fluids, wiring, and give the hoses a good grope.
I have taught the Warden (aka my gf lmao) to be way more observant then she was when we met and because of this her car is still around after blowing a HG twice, an alt belt, oil pump, and various coolant tubes popping.
Small noises, different rpm changes, lights, smoke, smells.. They all tell a different story.
(http://i299.photobucket.com/albums/mm307/J_holubek/84%20Jetta/383662_10150483393769707_505369706_8533109_1399236127_n.jpg)
(http://i299.photobucket.com/albums/mm307/J_holubek/84%20Jetta/402745_10150502630864707_505369706_8622289_613792234_n.jpg)
Two separate occasions, her knowledge of shiit has come in handy when she was stuck on the side of the road. First picture, blown heater core clamped off with vice grips and pliers. Second pic another blown hose. remove rad cap pressure and tape and tie the hose. made it home 80kms!
Women are NOT the problem
However, it doesnt look good for the op's car.
Post by: CRSMP5 on February 06, 2012, 08:56:47 am
i said no bad towards women.. i only spoke of a how to prevent due to guys wife issue of over heat..
you know newer vws have a big spot between speedo/tach that say no oil pressure says TURN CAR OFF??? and i know a guy who kept going... LOL... i also know a guy who WORKED on cars for 7 years or so thru high school and collage who blew up his 1.8t as he felt the same light did not pertain to him...
so lots of idiots fail to shut it off in bad times...
i just find it funny anytime she has car it has issues.. IMO she dislikes car and trying to kill it...
Post by: R.O.R-2.0 on February 06, 2012, 10:39:04 am
your right, only the ignorant people are like that (both male and female)
my mom is one of those people who catches things before they get bad.. but ive known ALOT of girls that have killed their cars from pure ignorance..
one bottomed out her car, ripped off the oil pan, and then called me, and wondered why her car was knocking, and her oil light was on?
Post by: Vohaul on February 06, 2012, 01:08:59 pm
Lol.... She didn't find it that funny ..She refuses to touch the car
.. Anyway went the parking lot it sat in the next day and replaced belt, topped off all fluids, checked for leaks, jumped it, and drove it home (75 km)
Been back to work and everything seems fine.... I'm guessing with all the headlights ( quad beam relayed projector headlights and big stereo going it killed the battery before the engine went AWOL.... Probably helped she put almost 3 liters of coolant mixed in before it shut down
I am curious though .... Why did the aaz shut down on its own... It's my understanding that the only electric part of the engine was a temp sensor or something.... Fuel pump?
Post by: Baron VonZeppelin on February 06, 2012, 11:15:02 pm
Nope.
Just on average -like 92.5731 % is the number iirc
...when I busted the oil pan on my NB, I stopped right away and turned off the car.
(she didn't want to back up because there was a spider still on the loose behind her in the parking lot - that she was fleeing from.
so she charged forward over the parking barrier (oil pan bang).
blocked in by the cart return railing - she turned off the car and played dead hoping the spider would pursue other prey.)
(^writers embellishment^)
Jess is an expert driver and avid wrench,
idunno how the oil pan got busted
but she probably fixed it herself.
Further, she would have caught the broken serp belt on Vohauls car-
replaced it in the parking lot and called only to cuss about lack of proper maintenance. lol
Post by: Baron VonZeppelin on February 06, 2012, 11:20:27 pm
Voltage drop probably shut off Inj Pump.
12 volt solenoid on Inj Pump controls fuel going to injector lines.
Its the only wire you "have to have" to run your cars engine.
