General Information => General => Topic started by: R.O.R-2.0 on January 09, 2012, 10:15:02 am
Title: Got a new 10mm injection pump.. couple questions?
Post by: R.O.R-2.0 on January 09, 2012, 10:15:02 am
so, i got a bosch VE pump for a peugeot 505TD.. its got LDA, manual stop lever, and a 10mm head/plunger..
part number 0 460 404 020.. only thing i can find online is that it is a peugeot pump, but i already knew that..
what sort of advance spring do they have? what type of governor? anything special about the pump, other than the 10mm plunger, and cool LDA assembly? whats up with the SUPER LONG delivery valves?
i KNOW i need to re-case the pump in a VW case, or take the 10mm plunger/springs/camplate from the pug pump and install them in a VW unit?
pics to come!
(http://i702.photobucket.com/albums/ww28/Dubsmoke/P1000515.jpg)
(http://i702.photobucket.com/albums/ww28/Dubsmoke/P1000518.jpg)
(http://i702.photobucket.com/albums/ww28/Dubsmoke/P1000513.jpg)
(http://i702.photobucket.com/albums/ww28/Dubsmoke/P1000509.jpg)
(http://i702.photobucket.com/albums/ww28/Dubsmoke/P1000511.jpg)
Title: Re: Got a new 10mm injection pump.. couple questions?
Post by: R.O.R-2.0 on January 09, 2012, 06:51:38 pm
awe, come on guys...
seriously? nobody knows ANYTHING about this pump?
23 views and not a single response??
Post by: R.O.R-2.0 on January 09, 2012, 07:14:07 pm
any reason why i cant just drill new holes in my bracket, and just bolt this pump up?
is it really that important that our pumps have 3 bolts up front holding them to the bracket? or would 2 suffice?
theres plenty of other vehicles that mount the pump with 2 bolts on the nose..
Post by: burn_your_money on January 09, 2012, 08:26:46 pm
I don't see why you couldn't just drill holes in your bracket. That inner one will be a bugger to get at though.
It's a right hand rotation pump, but you already knew that.
Those look like normal AAZ delivery valves from here.
Post by: R.O.R-2.0 on January 09, 2012, 09:20:00 pm
yea, never seen an AAZ pump in person, so i wasnt sure if they were the same or not. should i swap in the 1.6 DV's, or keep the pug 2.3 DV's in the pump and bend my lines?
right hand rotation as in clockwise, correct? the PUG rotates the same direction as the VW.. i checked direction of rotation on my buddies 505 TD..
and i dont think it will be too bad getting at the inner bolt to tighten it, a flexible gear wrench should take care of it no problem.
thanks for clarifying that i can just drill new holes, because this is a supposed running pump, and i really didnt want to have to cannibalize it to build a different one..
and tyler, do you have any idea what governor spring setup this pump has? think its got the caged automotive style springs, or the big single truck/industrial spring?
Post by: burn_your_money on January 10, 2012, 05:48:12 am
Since it's off a car it's probably a very similar gov assembly to the one in a VW. I don't have access to any of Bosch's programs anymore so I can't check for sure.
I would swap in 1.6 DVs and see how it runs, unless you have spare lines that you don't mind ruining.
Yes, right hand as in clockwise.
Post by: R.O.R-2.0 on January 10, 2012, 07:29:35 am
ok, thats what i was thinking.. i have PLENTY of 1.6N/A DVs, and NO EXTRA LINES.. so thats the ONLY logical option..
and i was 99% positive that this was the correct rotation pump for my engine.. thanks for clearing that up.
i went ahead and sucked it full of ATF, to break up some of the gunk. i just hope the seals are still OK, its been sitting for who knows how long in a box with nothing in it, just dry..
the pump turns over nice n smooth tho..
is there going to be any adverse side-effects from running a bigger pump? harder to time? less economy? more smoke?
Post by: theman53 on January 10, 2012, 07:46:31 am
Yes.
The cummins pump I have had a real narrow window of timing, there is more smoke, and I used more fuel with it in there. I also think that with all the timing I had to run it helped loosen the precup that fell.
Post by: R.O.R-2.0 on January 10, 2012, 07:54:58 am
Yes.
my car runs good, maybe i should just put this on the shelf for a while?!?
Post by: MJF on January 10, 2012, 08:16:37 am
I've had a couple 10mm pumps made of Toyota pumps. FWD Audi got better mileage with it than with stock pump. No smoke or nothing else negative.  Just more fuel and more power :)
Post by: burn_your_money on January 10, 2012, 08:28:05 am
That's a bad thing. It should be very notchy when turning it. 4 distinct notches to be exact.
You can throw the timing specs out the window because the different rotor will change everything. You will probably need less advance but it will depend on the characteristics of the head and rotor
Post by: theman53 on January 10, 2012, 08:37:49 am
Giles told me for my 12mm bosch to time it between 1.20mm and 1.30mm, I would guess a 10mm to be in the 1.10 to 1.2 if things go somewhat linear.
Post by: R.O.R-2.0 on January 10, 2012, 11:19:53 am
well, yea.. its notchy like a pump should be. you can feel the cam plate riding over the rollers, and the resistance from the springs.. i simply mean it doesnt bind up, or grind, or anything like that. i mean it turns over nice and smooth as in "as smooth as a good pump should be".. i dont mean that you can literally turn it 360* with no resistance. sorry for the mis-understanding. i also popped the timing plug out of it, and the plunger moves up and down like it should.
and what do you mean about the "characteristics of the head and rotor"?? the car it was in, also has 130bar injectors. could i be safe to assume that the PUG timing spec would be safe to use on my engine as a base point? im also running 130bar injectors at the moment. would i benefit any from using 155's with this pump?
also, theres no cold start advance on the pump.. thinking i should add one, correct?
Post by: R.O.R-2.0 on January 10, 2012, 11:42:20 am
Yes.
well, can we really compare a 10mm Pug IDI pump to a 12mm Cummins DI pump? your 12mm pump prolly had a 4mm cam plate. i imagine my 10mm pump probably has the same 2.3mm cam plate that the stock VW pumps have. that should be the deciding factor for timing, i would think..
as for fuel consumption, how much did your economy go down with the 12mm pump?
a 12mm pump is HUGE on a VW btw..
Post by: R.O.R-2.0 on January 10, 2012, 11:44:33 am
Wonder if maybe i should just call Giles and pick his brain about this pump? im sure he has had to have dealt with atleast one of these..
Post by: BillyWillicker on January 10, 2012, 03:29:07 pm
That is a very nice pump to recase for a VW.  This, I would do...
 Use VW case.
 Add cold start advance, with VW advance piston and spring/shims.
 Keep mechanical shutoff.
 Use ENTIRE VW governor assembly, shaft, weights, springs, etc. Also turn gov. shaft 1/4 to 1/2 turn in. from previous setting.
 Compare boost pin/spring and use whichever can get you the stiffest spring/least preload/most travel for      the smoothest transition into and across boost range.
 Use 1.6l delivery valves/pipes/130bar injectors.
 Shim plunger return springs .010-.020" for higher RPM
After you have it all assembled, time as you have been.  You prolly know the rest of the game and prolly also have figured on all of the above.  Also I make no guarantees on the durability of your engine running the pump described but it aughtta be a pretty hot pump.
Post by: R.O.R-2.0 on January 10, 2012, 04:09:07 pm
i was gonna just drill my bracket to accept the pump body as it is..
was also gonna take the top off the pump, and shim the governor.
why do i need the VW advance piston/springs/shims? whats better about it? the Pug spring should be softer, its a lower RPM motor..
why do i need the WHOLE VW GOVERNOR? i dont really wanna mess with the actual governor weights and all that stuff..
whats the advantage of the VW governor ASSY over the Pug assy?
why would i want to shim the advance return spring? everyone is raving about going to SOFTER springs.. shimming it will make it stiffer, and limit the travel even more, if im thinking correctly..
Post by: BillyWillicker on January 10, 2012, 04:35:15 pm
The pump build I outlined will be a great, tuneable to a VW 1.6l TD, rather than tuning a 2.3l lower RPM set up pump to match the characteristics of a 1.6l higher rpm engine.  The mods described will make the pump tuned to the characteristics of the engine it will be installed on.
If you keep it as it is it will never work exactly how you want, though it will probably work OK.  If you put it together as outlined it will be easily tuned how you want.
Also I meant to shim the injection plunger return springs, not the advance piston spring, it will allow higher RPM.
People act like 'OH MY GOD!!  Its an injection pump!  I'm scared of it!!!'  Just try it out as is.  If the snout won't mount a VW sprocket your kinda obligated to take it apart, it looks like it wont take one.  If it dont work out, try something new.  These pumps are very tuneable and easy to adjust.  The bosch books are out there and explain how all the functions work, and are adjusted.
Post by: BillyWillicker on January 10, 2012, 04:47:57 pm
Yes, do the Gov. Mod,
WHY #1 - The VW advance springs/piston/shims work for a VW, the PUG will put in too much advance too early and not enough later.
WHY #2 - The VW governor weights/shaft/springs work for a VW, the PUG will pull fuel too much too early, you will never get the revs you want
WHY #3 - Oops, I meant plunger return springs.
Also the softer advance springs people rave of work, but they are using softer VW springs aren't they?  Higher RPM will be had with more advance and stronger plunger return springs, more advance is gained from trimming the advance piston and advance rod channel.
Advice freely given and not spitefully revoked from the forum either.
Post by: burn_your_money on January 10, 2012, 06:45:47 pm
You would basically have to tear the whole pump down to add a cold start advance so I wouldn't bother, unless you actually find you need it.
by "characteristics" I mean things like the various fuel channels Bosch seems to randomly put in different pumps, the style of the spill port, the offset of the fill port in relation to the high pressure discharge ports and many other things that Bosch doesn't elaborate on.
I think you will have to just play around and see.
Post by: R.O.R-2.0 on January 10, 2012, 07:14:41 pm
so, if i want CS advance, i have to pull the pump apart and swap the VW advance piston in?
and what do you think tyler? should i re-case it, or just leave it a whole Pug pump, and do the gov mod, shimming the governor solid.. it shouldnt matter what governor it has in it, if it has the gov mod, right? the gov mod effectively removes the governor, right? thats how i understand it..
and Billy, i had never thought of shimming the plunger springs.. that will effectively raise the RPM ceiling of the pump.. it will have more pressure from the springs to keep the cam plate from skipping on the rollers..
Post by: BillyWillicker on January 10, 2012, 07:45:14 pm
Yea, RPM ceiling, shimmed, sure...
Also the gov mod does not remove the governor, it only delays its onset and "artificially" raises the rpm ceiling.
You got lucky with that PUG pump, it has ALL the parts to build up the ultimate VW IDI pump.  If I had those parts that's what I would do.
See what burn_your_money says, ask a few more ppl too, get as many opinions as you can.
Post by: burn_your_money on January 10, 2012, 08:00:07 pm
You can open up the engine side of the advance and see what style piston the pump has. Most likely it will be flat like the TDI ones. That one would require tearing down the pump to make work with a CS lever. If it has the metal bar going across it then you just need to find the proper advance mechanism. I think the VW pumps alone have 3 different styles.
It's a lot easier to drill 2 holes and mount up the pump then to recase it. I'd start with that and see how it goes. You'll probably need to swap on the VW rear plate to the pump head. Hopefully the head has the proper holes for mounting it.
Like BillyWillicker said, you will likely have issues with the advance, although if the pump is worn it may actually work out for your benefit. And you might even like the advance coming in faster. You'll have to try it with a keen ear and a close eye on the EGTs and see what happens.
I think you will be alright just shimming the governor. Depending how much you shim it you could be raising the RPM to like 10 000 RPM, which you'll never hit (hopefully). If you shim it solid, then yes, there is no max RPM governor.
If you do recase it, make sure to get an old pump housing that has the same style of gov shaft (reverse thread) If you get a newer housing make sure that the shaft is the same and use the one for the housing.
Post by: BillyWillicker on January 10, 2012, 09:09:47 pm
OK, wait....  Modding the pump mount provisions to accommodate a different pump is easier than mounting a stock case pump?
Post by: burn_your_money on January 11, 2012, 04:56:50 am
Drilling 2 holes vs taking 2 whole pumps apart and swapping it over? Sounds way easier to me
Post by: 8v-of-fury on January 11, 2012, 06:51:34 am
Are we talking of shimming the springs that reside where my red marks are? Sorry for the crap picture, cellphone.. i wasn't gonna get the camera dirty.. ;).
(http://i299.photobucket.com/albums/mm307/J_holubek/Diesel/IMG01258-20120105-1442-1.jpg)
If so, then how much shimming are we talking? I would be interested in being able to try this and having the pump be able to sustain higher fueling  capabilities.
Post by: R.O.R-2.0 on January 11, 2012, 09:25:57 am
me too.. clamp the pump to the bracket, drill 2 new holes, weld nuts on back side, bolt on pump, time, start.
that sounds ALOT easier than tearing down 2 whole pumps. the only parts pumps i have, need pump shaft bushings..
this PUG pump needs nothing AFAIK
and yes, it has a FLAT advance piston. i was a bit sad when i popped it open and saw that..
it also has a blue (or black) timing advance spring..
and FWIW, the VW rear bracket should bolt right up no problems.. the rear of the head has the same holes/mounts as a VW..
and Billy, the governor weights act on the governor springs.. if there are no governor springs to compress, i dont care what governor weights are in the pump, the governor will be disabled.. shimmed solid means exactly that.. governor springs shimmed solid, or almost solid..
Post by: BillyWillicker on January 11, 2012, 03:20:30 pm
Yes, shimming a few mm's out of a device that travels a few mm's can disable it.
I have experience with high strung turbo gas cars, I like the way power is delivered - all balls until the rev limit.  A diesel governor is very different that it gradually rolls the power back.  I am working at a governor setup that will act like a gasser rev limiter, that way there is still a safety measure in place and anyone who else who NEEDS to use my car can without a training course on how to not destroy the engine and still enjoy driving it.  I think that if all diesels were made this way they would be far more popular with the general public.
Anyways, back on topic, I can donate a pump housing with the parts you would need if you like, I'd have to check but I'm pretty sure it has good shaft bushings in it, if not, I could replace them.
Post by: R.O.R-2.0 on January 11, 2012, 05:37:21 pm
my governor acts exactly as a gasser would.. pulls clear till the rollers start skipping..
Post by: 8v-of-fury on January 11, 2012, 05:41:18 pm
I can pull the needed 57-5800 rpms in 1st through 4th gears to get the rollers skipping. It stops injecting immediately and power just cuts off.
Much like a gasser would when rev limiter is hit. Also my governor is no longer a spring, but a solid piece.
Post by: BillyWillicker on January 11, 2012, 05:53:49 pm
Cool!!  Does the accelerator pedal push back against your foot when its all wound up or is it not even noticeable?
Post by: R.O.R-2.0 on January 11, 2012, 06:37:39 pm
yup.. same deal on the governor.
5750 is the end of the power..
