Engine Specific Info and Questions => IDI Engine => Topic started by: xxkoadyxx on December 19, 2011, 04:56:47 pm
Title: compatable clutches for aaz in 93 golf
Post by: xxkoadyxx on December 19, 2011, 04:56:47 pm
I'm wondering what clutches I can use in my 1.9TD without modifications? My clutch in my car needs to be replaced as its slipping..
Thanks guys :)
Title: Re: compatable clutches for aaz in 93 golf
Post by: burn_your_money on December 19, 2011, 08:54:22 pm
Are you sure it's not just the silly auto adjusting cable messing up?
Post by: regcheeseman on December 20, 2011, 04:37:48 am
The AAZ is a 210mm flywheel IIRC - just replace it with a decent replacement AAZ clutch?
Unless you want to change the flywheel? I think I'm using a TDI fly with a HD 16V gasser 228mm plate
Post by: stewardc on December 20, 2011, 05:50:45 am
I got an ACT setup for my AAZ. It's sweet and it'll handle any mod I want to make to the engine.
Post by: xxkoadyxx on January 09, 2012, 07:54:35 am
is the 1.9 a 2 dowel flywheel?
im looking at getting this http://www.autopartsway.ca/PartList.cfm?Volkswagen/1993/Golf/Base/1.9L_L4/allB/Transmission_and_Transaxle_-_Manual/Manual_Transmission_Components/Clutch_Pressure_Plate/pagenum1/tabS (http://www.autopartsway.ca/PartList.cfm?Volkswagen/1993/Golf/Base/1.9L_L4/allB/Transmission_and_Transaxle_-_Manual/Manual_Transmission_Components/Clutch_Pressure_Plate/pagenum1/tabS)
matched with a ACT clutch.. How would that work? what else would i need? Do i need new bolts and such for the flywheel ect? also plan on doing this also sense i have it apart- http://www.autopartsway.ca/partlist.cfm?Volkswagen/1993/Golf/Base/1.9L_L4/allB/Transmission_and_Transaxle_-_Manual/Manual_Transmission_Components/Clutch_Push_Rod_Seal (http://www.autopartsway.ca/partlist.cfm?Volkswagen/1993/Golf/Base/1.9L_L4/allB/Transmission_and_Transaxle_-_Manual/Manual_Transmission_Components/Clutch_Push_Rod_Seal)
What is your guys thoughts? Any thing else i should do sense i have it apart?
thanks! koady :)
Post by: R.O.R-2.0 on January 09, 2012, 09:27:41 am
x2..
the auto cables are JUNK..
and often take out clutches early.
Post by: stewardc on January 09, 2012, 09:29:53 am
Mine is 2-pin and that pressure plate should work nicely on a stock motor. That is the stock PP. If the motor is stock, simply use the OEM clutch disc also.
Post by: xxkoadyxx on January 09, 2012, 09:47:58 am
alright thanks! well i ordered the pressure plate..
The motor is stock-ish, 1.6 boost pin, fuel up some, boost up some, stright pipe with muffler and TDi intercooler (soon) and intake
Post by: R.O.R-2.0 on January 09, 2012, 09:54:56 am
you can use a 16v clutch and pressure plate also..
i know the 16v pressure plate is the best/strongest one you can get in terms of stock 020 pressure plates..
Post by: xxkoadyxx on January 09, 2012, 10:18:53 am
alright, thanks!  8)
